Corrosion in Electric Panel ... What to Do?
   / Corrosion in Electric Panel ... What to Do?
He can only do that IF he has or can run a 4th conductor between the two panels. It may not be possible/feasible.
Upon closer inspection, the sub panel does in fact have the 4th conductor run from the main.
   / Corrosion in Electric Panel ... What to Do? #22
That's good news GP.
   / Corrosion in Electric Panel ... What to Do? #23
if you have 4 feeders from main, it should be a piece of cake to replace. one suggestion, get a weatherproof NEMA 3R rated panel. these are designed for outdoor use. also, as stated before, dont attach directly to the wall. install a spacer. I generally install deep unistrut to the concrete wall, then install the panel to the unistrut with 1/4" bolts and unistrut spring nuts (they lock themselves into the unistrut).
Silicone the heads of all attachment screws/bolts that you use. get a larger panel ... like either a 30/40 space or a full 40 space to eliminate the doubled up circuits.
good luck
   / Corrosion in Electric Panel ... What to Do? #24
A question to the forum ... Since this is now a sub-panel. Should the neutrals be separated from grounds ? I noticed the panel grounding lug is connected to the neutral...
I was wondering the same thing.
Just to let you all know, I took your advice and replaced the panel and breakers. I also floated the neutral, and eliminated the 1/2 space cheaters, and all breakers have only one wire. The local inspector approved it this morning.
Thanks for your support and advice.
GP.
   / Corrosion in Electric Panel ... What to Do? #26
GP.
Good deal, now you can sleep better without worry.:thumbsup:
   / Corrosion in Electric Panel ... What to Do? #27
per code the sub panel should also have its own dedicated path to ground. eg its own ground rod.
   / Corrosion in Electric Panel ... What to Do? #28
Good to hear you replaced it. I agree it didn't look very good. Not something I'd be willing to live with.
Chad
Hmm. I pointed out to the inspector that, in this subpanel in the house, I did not ground the neutral and kept the grounds separate from the neutral. The main panel has two ground rods and the ground is run to this subpanel ( 4 wires to subpanel, two hots, one neutral and one ground). He said that is the correct way to run it.
I admit, I'm not an electrician and am no expert on code, but this is the way he said to wire it.
He also said that when I run to another subpanel to the barn, to bring 4 wires to the barn sub, float the neutral and that I won't need to keep the ground rod there that I recently put in.
   / Corrosion in Electric Panel ... What to Do? #30
This is the case with a feeder to a subpanel in a detached structure, such as a detached garage.
When the sub panel is in the same structure and is wired with a 4 wire feeder (L1/L2/N/Gnd), the sub panel does not require a supplementary ground rod.
Wrooster
CUSHMAN HAULER PRO ELECTRIC GOLF CART (A54756)
CUSHMAN HAULER PRO...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
CATERPILLAR 963C CRAWLER LOADER (A52705)
CATERPILLAR 963C...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
