I got $1,000 to spend on a welder, help me spend it.
Status
Not open for further replies.
   / I got $1,000 to spend on a welder, help me spend it.
It is my fault for assuming that the welder came with a very small roll of wire.
I looked at tons of competitors welders and lots of them showed a small
roll of wire.
That is where my assumptions came from.
No biggy, I can get the wire on Monday, if he has the ESAB.
   / I got $1,000 to spend on a welder, help me spend it. #122
Mark Everlast - curious about your comments on not using copper coated wire. The reel I got with my wirefeeder is 035 cu coated wire (no idea on brand). Seems to work fine. Given that it lives in an unheated garage, I was thinking that the cu coating was a good thing. The reel is almost used up, so since I will be buying more, I wanted to get some mroe info on which one to use.
Markcuda - good deal on the larger cylinder. Unless you are doing tons of work, it will last you a long time in a home shop. I've had my 125cf cyl over a year and still on the initial fill. Now I'm not a heavy user, but it seems to hold out a lot longer than I expected. Especially when compared to my oxygen cyl for the oxy/propane cutting torch, where I went through 3 oxy cyls on the first big project I had...
Yup, I figured I better bite the bullet and get as big a tank as I could handle.
Speaking of handling, this 250cf is about all I want to wrestle around onto
my trucks tailgate. ;)
The guy had a 300 something size tank, a inch bigger around
and about 5 inches taller, I said "no way" LOOLOLOLLOLOOLOL
   / I got $1,000 to spend on a welder, help me spend it. #124
We don't seem to have the 250 around here. Just 125 and then 330 for the next size (and the biggest). 250 sounds like a very good home shop size. I might upgrade if I find I am running through a lot...and can find the space...
   / I got $1,000 to spend on a welder, help me spend it. #125
Copper flaking for one. It gets ground into the drive roll and can cause feeding issues. It's also a contaminant. Ever wonder where that copper goes? Either into your lungs or into the weld. But regarding the wire I recommended, here's a brief summary in the first few pages about copper coated as well. It's not the only place you can find similar information. http://www.esab.com/aristorod/en/why/upload/SWR-10056-OK-AristoRod-Welder-Guidebook.pdf
Dave, my tank is called a "K", with the cap on, it measures 52 inches tall.
I know, that is not how the cylinders are measured.
It is about 9 inches in diameter.
If I recall correctly, it weighs 117ish pounds.
Mark, will that bare wire rust in my garage?
   / I got $1,000 to spend on a welder, help me spend it. #127
My 125 is about 4' tall, 7" dia. Not too different, but a big chunk of volume!
Mark- All good and well, but when the wire is intermittently used in a home shop garage (unheated) by a guy like me...it seems the anit-rust protection of the copper coating would beat the potential downsides. I can understand why it would be best to avoid that in a production environment. I want to get one of the lager spools (44 lbs?) to avoid having to do it again to quickly or running out too fast when I really need it...
Dave, how far are you from EauClaire?
   / I got $1,000 to spend on a welder, help me spend it. #129
Hour and a half or 2. I'm near Hudson.
Ok
I was born and raised in EauClaire, moved to this God forsaken state in 77.
Status
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2013 Fiat 500c Lounge Hatchback (A48082)
2013 Fiat 500c...
2025 K1230 UNUSED Knotted Wire Mesh Field Fence (A50860)
2025 K1230 UNUSED...
2016 Chevrolet Tahoe LS SUV (A48082)
2016 Chevrolet...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
