Canvas tarp best for covering equipment?
   / Canvas tarp best for covering equipment? #11
Doing it this way I can cover with a plastic tarp and tie it down good. Things do real well this way. Canvas tarps can become a soggy mess.
I use plastic pallets, but not everybody has access to them. But I used a plastic tarp only once. Too many sharp edges on a chipper. After a couple of good winds, it was shredded. A properly treated canvas tarp should not become a soggy mess. But if you just drag an old out out of the shed...... Even old ones - assuming the mice haven't started on them - can be restored with a preservation treatment. I linked to an example earlier.
//greg//
   / Canvas tarp best for covering equipment? #12
I have had good success with EPDM rubber roof membrane. It is durable in sunlight, breathes any trapped moisture, yet is waterproof. Very tough.
Try and find a roofer in your neighborhood who does that type of roofing. Often they have used pieces from roofs they replace which still have a lot of use in them.
Carlisle is one of the major brands, Firestone may still be in the business.
The material is often used for pond liners.
Dave M7040
//greg//
Thank you all for the good info. No canvas at Menards so I brought home a 4 wheeler cover but..."too many sharp edges on a chipper." I am heading to tractor supply in a few minutes to get a canvas tarp. I was just outside and pulled the chipper off my trailer onto a pallet, but putting plastic underneath makes sense to me. I suppose I could drag it off and put plastic under there. It isn't that heavy. Yeah, that is what I will do, it makes sense to me. Maybe this summer I can get a machine shed or something built. Being outdoors sure takes its toll on stuff. My poor kubota looked like new before I started parking it outside all year. : (
Quick edit: put a piece of rubber on top of the pallet then set the chipper on that. Should block the ground moisture. Wrapped the new 10 X 12 canvas tarp around the chipper with 4 tie downs and should be good till spring. I took the shoot off and stuck it inside.
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
