4tnv88 Block Heater
   / 4tnv88 Block Heater
I forgot to add regarding hose heaters, there seems to be a problem with most of them tripping circuits in GFCI 110V outlets. I know this is the case with the hose heater that came with my 93' GMC. Naturally all my outdoor outlets are GFCI so I've never used it.
   / 4tnv88 Block Heater #12
I have two heaters in my 336D, one in the block 750W and one in the transmission / rear-end 1KW. Only problem ever encountered was the rather rude surprise contained in the electric bill. Since my place is mostly for week ends duringthe winter I use a swimming pool timer goes on a noon thrusday and off a midnight Saturday.
Big savings paid for it self the first month.
   / 4tnv88 Block Heater #13
Hey Gang....I am hijacking this thread as I believe the original poster worked out his problem....If I need to start a new thread...please let me know.
So with Winter in full swing in New England, my YM2020D with the 3T82B-N engine struggles but always starts when its really cold...I just don't like the idea of it struggling so much and was thinking of installing a block heater that Hoye Sells - but I do not want to touch the block if there is a significant possibility that I screw something up. In Katahdins original post and picture, he has a plug that has a square hole that would seem logical that it would unscrew. However in my block I only have plugs and something that I am wondering if its possible was designed to accept a block heater. Please see the image below and the plugs are labeled "B" and the mystery area is labeled "A". If I need to pull the plug B - how is that done and do I need to tap that hole? Thats a pretty big hole to tap????. What is "A"? By the way this is the "passenger side of the tractor.
   / 4tnv88 Block Heater #14
No idea about A but I would say B is press in freeze plugs. Stupid question I guess but what is on the other side of your block? I thought that was where the screw out plug was. Right above the starter.
I have come across in my research a block heater that looks like it could fit A: Zerostart part number 3500001. Its listed for the Yanmar 3TN66 and 3TN72 engines. Maybe it'll also match up to yours?
ZeroStart - 350-0001 - Circulation Heater
   / 4tnv88 Block Heater #16
I've installed and used both. The inline rad hose install was more of a chalange working in a tight space. It was a Kats, and went into the 3T84 in my YM3000. Had to drain the coolant. Almost the same engine in my JD950 got a screw in block heater. ( 3T90J ) Hex head plug was behind the starter, had to remove the starter to unstick the plug, had to give it a little heat to break it loose. Think the 950 heats up faster with the block heater than the YM3000 did with the hose heater. Think a little more of the heat transfered to the radiator in the YM3000 than with the plug in the JD950. If I have it to do again with my new to me 970, I'll opt to do the screw in heater. I like unplugging the removable cord and getting it out of harms way in the summer.
Chris
   / 4tnv88 Block Heater #17
A looks to be a cover into the crank area ie"oil behind it,not water" and B we here call them welsh plugs which are in the water jackets. i think you would struggle to tap those big sucker holes, plus i dont think there would be much room behind it either to get much depth?
   / 4tnv88 Block Heater #18
Glad you said something Winston.....I didn't see this even after looking a few times....Its 17 degrees out today....I would hate to have to start the tractor today....So I can assume this is the plug the block heater would go - So, some propane heat the some force and I should be able to get it out? Will I lose all of the coolant or just a bit like Katahdin did?
   / 4tnv88 Block Heater #19
I am thinking that plug should measure appx 1-5/16". That is the appx diameter of 1" pipe. Pretty confident that is the thread size on the block heater that Hoye sells. Tapping on a pipe plug can sometimes help in removal. Penetrating oil is next to useless in my opinion because tapered pipe plugs are made to seal and they do. :D I am not sure I can tell from your picture but that looks like a square head rather than a square socket? I wouldn't think you would loose over half your coolant if that much.
   / 4tnv88 Block Heater #20
After a lot of plumbing repairs on a hundred year old farmhouse - unscrewing anything with large pipe threads scares me. It would be my luck to tear the head off that 30 year old plug before the plug unscrewed. And using a huge breaker bar risks bumping unrelated components.
Approach with caution!
re losing fluid - first remove the radiator cap to relieve pressure.
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
2018 John Deere Z997R (A53317)
2018 John Deere...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
