Boom Pole used for Vehicle Recovery
   / Boom Pole used for Vehicle Recovery
Doesn't it have a knob that pulls out/in to free wheel ?
Even if it did, I'd still go your route.
Although that chain gives me the heebie jeebies. Probably fine thou.
No neutral/freewheel that I can detect. Just a throttle lever and a fwd/rev pedal.
You'd be surprised. I used them to hold wire mesh onto the brush guard of my four wheeler. Rarely had to replace any.
I've got different sizes from 10" 50# rating up to 28" 175# rating.
That's right. If you ever tried to remove one without the aid of snips or a knife, then you have some idea of what they will take in tensile (stretching) load. As long as you don't wrap them around any sharp corners they will hold a surprising amout.
   / Boom Pole used for Vehicle Recovery #14
Baby Grand......That Boom Pole made your day. Sometimes I forget that I have one. You told us in another tread as to why you have the chain link attached to the ROPS, but I forgot. So, what was it?
When pulling ropes and chains I get a deep, uneasy feeling - something along the lines of "what if that rope snaps and it comes at my head like a freight train?". I noticed that many of the logging winches now come with a screen up top to protect the operator and decided that even if I couldn't afford a new logging winch, I could knock together a serviceable screen. I also use it to carry my loppers and spare bungie cords:
   / Boom Pole used for Vehicle Recovery #16
That chain gives you alot of range and is quick to adjust too. I like it. :thumbsup:
Thanks, Gordon. That was a bonus that I hadn't anticipated - large adjustments can be made much more quickly than with a turnbuckle type of toplink.
Willl brought up a good point about safety. In using this arrangement I took into account that there is some risk to using it, in that the boom can swing back at the operator unchecked. Something to keep in mind.
   / Boom Pole used for Vehicle Recovery #18
chain is often used as a flexable top link for some brush hogs.
Yeah and if you hit something with the front the rotary cutter could come on you.
   / Boom Pole used for Vehicle Recovery #19
as the driveshaft on the PTO with standard U-joints only has a flexablity of about 15 deg not to mention a limited amount of compression in the length, it will be a LONG LONG way from "comming on me"
   / Boom Pole used for Vehicle Recovery #20
Your tractor does not have enough power to bend a PTO shaft? At a minimum you have a very good chance at wasting a shaft if you hit something with the front of the cutter.
Landoll Hauloll (A52128)
Landoll Hauloll...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
