How do you guys compact your gravel driveway?
   / How do you guys compact your gravel driveway? #1
wreckedit
a little upstate NY
Kubota L3130
I appreciate the advice I just got on blades, rakes, and LP/GS. I guess the one thing I forgot is compaction. If you read around and look at youtube vidoes put out by state highway departments on rural road (non paved) maintenance they always use a roller to compact because , well, they have one. For the rest of use, is driving up and down over a newly "ripped then crowned then groomed" gravel driveway enough?? Or without a real roller am I wasting my time?
Thanks!
   / How do you guys compact your gravel driveway? #2
I try to groom the lane when the ground is soft and traffic is light. That gives it a chance to settle and the stones are more easily set back in the road. Vehicle traffic is the only compaction I use.
   / How do you guys compact your gravel driveway? #3
That is the one thing that I will rent is a roller. Not expensive and does a great job on a long gravel drive and it will make for a long lasting surface. Probably once every five years. Also find a neighbor to share the cost and do more than one on the same rental.
   / How do you guys compact your gravel driveway? #4
I blade the drive after a rain, when still soft, then instruct the wife and kids to drive a different path each time, to pack it down, it works good.
   / How do you guys compact your gravel driveway? #5
I wait until the drive is very wet and it is lightly raining. I use my jd310 FEL to backblade uphill his puts a lot of pressure on drive and pulls gravel back up the hill.
   / How do you guys compact your gravel driveway? #6
I use a box blade to crown and smooth it out about every two to three years,, then let the traffic repack it for me,, Lou
   / How do you guys compact your gravel driveway? #7
I dont really have much driveway just a large area between my shop and house. Driveway is only about 40 feet to that large gravelled area. I just backblade it with the FEL occassionally. I tried doing it with the landscape rake but had mixed results and always had a row of rocks that I had to spread out with a garden rake. Backblading seems to work pretty good then just drive over it. We dont have a lot of traffic on it to start with and maybe one day I will just remove the rocks from road to garage outside slab and put down concrete. I can then use the rocks on the shop area. Maybe next spring or summer job for this IF I decide to do it.
   / How do you guys compact your gravel driveway? #8
I maintain two miles of gravel road for the neighborhood. We use road base for gravel which packs down quite nicely without a roller. I use the blade around four times a year to keep the big bumps out and bring the larger pieces of gravel back to the center of the road.
   / How do you guys compact your gravel driveway? #9
Tractor is heavy and a Box Scraper Blade makes it perfect smooth to drive on.
...possibly the most useful landscape attachment you can own for any little tractor fitted with a 3 point hitch.
If they can't get 'up' my driveway, they cant get 'to' my driveway because its normally better then the township road ;)
   / How do you guys compact your gravel driveway? #10
use a full bucket of dirt and back drag with the bucket almost level. can also use down pressure if you can keep things heading in the right direction.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
3HP Electric Fans (A50854)
3HP Electric Fans...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
3 pt Aer-Way (A50514)
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
