Trailer For tractor
   / Trailer For tractor #11
I made the mistake of buying the trailer first and going cheap, bought a 16' homemade job with single axel. Then I bought my BX 25. The trailer did not track well and the trailer + the tractor weight was the tail wagging the dog with my 1/2 ton truck. Found a good used manufactured 18' lift bed with tail and dual braked axels trailer; rated at 14,000#. It was still very quesy with the 1/2 ton truck. I did a lot of research and talked to a lot of folks both in and out of the trailer industry. My BX with FEL and BH plus two other implements and accessories weighs in around 6000# + the 2,000# trailer. The largest trailer dealer in our area (when I was pricing new) stated that; if I bought a trailer from him he would not hook it up to my 1/2 Ton truck in his yard but he would deliver (for a fee) to a neutral point and I could do what I want. He blamed liability; as my truck was not rated to carry the 8,000# load. I bit the bullet and bought a 1 ton Dodge 350 dually (used). I now have a dream to drive. I have had 12,000# on the trailer and din't even know it is back there. Moral; No matteer what you get you will probably sometime overload the 1/2 ton truck and find yourself in the ditch or worse piled into somebody else when things go wrong. Always get more than you need to have that safety margin and comfort zone. Side note: I sold that old trailer for $500 and when the guy came to get it he had a small compact car with a class 1 hitch with an adapter to class 2. When he put the load on the car the rear bumper was 6" off the ground and trailer sloping forward. Hope he made it where he was going, but then God seems to protect the fools for some reason, not my luck.
Ron
   / Trailer For tractor #12
For the setup you have we offer a 18' with (2) 3500lb axles, ramps and holders, brake on one axle for $1750. You need to deduct the weight of trailer (2 @ 7,000 lbs, trailer usually weighs around 1400lbs, max carry weight 5600lbs) to see if you are able to carry your load safely. If it were me i would go with 6,000 lb axles, better to have a little heavy axle, you may need it sometime.
Ben
Circle G Tractor Sales, Inc.
Jinma Tractor Parts, Farm Pro Tractor Parts, Farmpro, Nortrack, Agracat
   / Trailer For tractor #13
I used to drag around a 3 axle gooseneck with a tractor backhoe on it weighing 27,000 total with a 3/4 Ton pickup. If you use your head you can compensate for anything.
   / Trailer For tractor #14
And you could get away with only minor injuries while killing someone else or their entire family.
You sir, are the reason there are laws. Laws written in blood.
   / Trailer For tractor #15
If you think you are going to stop any trailer with 8,000 lbs on it on a dime then you are a fool. Inertia doesn't care what kind of pickup you have or trailer you pull. People get into trouble by not realizing the ramifications of pulling extra weight and the increased distances need for turning, stopping, etc. I never had an accident, never had a close call, but drove like I needed to and for every other driver on the road. Not sure what laws you think I broke.
   / Trailer For tractor #16
My bad. I just noticed you are in South Dakota.
Laws:
You must have a CDL if you operate:
A single vehicle with a gross vehicle weight rating (GVWR) of 26,001 or more pounds.
A trailer with a GVWR of 10,001 or more pounds if the gross combination weight rating is 26,001 or more
pounds.
And if you did possess the knowledge to acquire a CDL, then you wouldn't have made the statements that you did.
   / Trailer For tractor #17
Laws:
pounds.
They didn't require CDLs at the time.
   / Trailer For tractor #18
Thank you.
Let's try to keep information provided in these forums as current and accurate as possible.
Sometimes "tribal knowledge" and ego will attempt to prevail over common sense and what is legal.
Try to avoid this for safety's sake.
I digress,
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
More info coming soon! (A50323)
More info coming...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53473)
2022 New Holland...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
