Why you should change your oil
   / Why you should change your oil #172
I don't know about other brands but Toyota used different sized sending units for oil pressure. The simple idiot light switch was pretty small while the sensor that actually read the pressure is quite a bit larger. If you have a good OBD reader that can read each sensor you can tell what you have.
   / Why you should change your oil #173
I did verify our GM trucks have "real" gauges on most of the cluster. Ford has more idiot gauges. Our GM truck tans temp gauge travels up slowly, like it should. The Ford gauge reads "normal" before I drive out the driveway in winter.... lol.
Beware of Ford trans temp gauges. They are really useless unless you watch it all the time. I'd rather have the "EWS" like in our bigger CDL rigs. A real proportional gauge and a buzzer & light if the trans temp, engine oil pressure or air brake pressure reach high/low levels. Here's a good example of a Ford trans temp idiot gauge. Mine wont really warn you until it's too late:
dieselmann's editorial
now.. again.. .. that's NOT what I'm seeing on my ford PSD's. I have to be half way to work before my trans temp gauges are in the normal area. whent hey start they are at the bottom and travel up WAY slower than engine temp.
soundguy
   / Why you should change your oil #174
Are we POSITIVE there is not 2 gauge packages? One with gauges/idiot warning sensors and one with REAL gauges??
They do some stupid things among all manufactures with split year things as well as little changes like this from year to year.
   / Why you should change your oil #175
On a gas Ford they haven't used an actual oil pressure gauge since the early '90's I'd guess. Maybe a hi-po model had them, but not the run of the mill vehicles.
   / Why you should change your oil #176
all i'm saying is i know FOR SURE that my trans temp does not come up for at least 5-8 minutes of driving at highway speed. hay dude's comment of his trans temp coming up right after start when he pulls out of the drive is not what I am seeing. 5 minutes ago I just had to move my f250 around the shop yard to facilitate moving equipment... trans temp gauge had just started to creep TOWARDS the normal white area when i parked it. it was no where near the middle where it normally runs whenthe truck is warm.
so I can say that one for sure.. no guessing.
So this does make one wonder if perhaps the more heavily configured vehicles have more premium gauges? IE.. jo-bob average f150 gasser vs a f250+ diesel.. the diesel /. hd package is plenty more $$$
   / Why you should change your oil #177
Ford has real temperature readings for transmissions. You can monitor them to the degree in the gauge mode on the digital cluster too. Radiator and oil on F-150's are idiot gauges I believe.
   / Why you should change your oil #178
Its dependant on model. My 1997 and 2001 F150's had real gauges that were damped. There was a simple mod to fix that. When the oil pressure sending unit quit on my 2001, only the guage would drop to zero. The idiot light and CEL would only be tripped if the second sending unit (that feeds the ECM) failed.
My father's 95 PSD was damped, but it appears that his 94 F350 has live gauges.
Much of the info from the gauge panel is actually needed by the ECM, so "real" data is there. Its just that many manufactures don't want to deal with the idiot behind the wheel when they see a change in oil/temp/volts and freak out.
   / Why you should change your oil #179
An actual sending unit on a 2001 f150?
That's the first I've heard that. No calling you a liar or anything, but I've replaced a lot of oil sending units on those generation of trucks they've all been the on/off variety.
   / Why you should change your oil #180
Trans temp on superduty's is definitely a real gauge. I always thought engine coolant was too but oil pressure is a dummy.
My newest superduty traded the voltage gauge for the trans temp. While I like the trans temp I wish I still had voltage gauge instead of an idiot light.
2005 GMC TOPKICK DUMP TRUCK (A58375)
2005 GMC TOPKICK...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
2017 John Deere 5075E (A57148)
2017 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
