1982 Ford F-1200 front diferential oil change?
   / 1982 Ford F-1200 front diferential oil change? #1
chazdo2
auburn new york
walk behing power drive 21
does anybody know how to check or change the front differential oil on this tractor?
   / 1982 Ford F-1200 front diferential oil change? #2
what's yer manual say about plug locations?
   / 1982 Ford F-1200 front diferential oil change? #4
OP
Sorry for our comments which may have been out of line. I see where you are new member, and previously posted for help locating a manual.
TBN and its members will usually bend over backwards trying to help........I don't know the answer to your question...BUT, I did find an owners manual here:
http://www.ssbtractor.com/tractor_m...or_manual_make=Ford&tractor_manual_model=1200
They also have a service manual ...but it is very pricey.
Hope this helps, and WELCOME to TBN.
   / 1982 Ford F-1200 front diferential oil change? #5
SG, you just copy and paste that reply from the other thread ??
I hear you brother !!!
I didn't copy and paste.. not aware of another connected thread?
   / 1982 Ford F-1200 front diferential oil change? #6
i just read his 4 posts. 3 are crosses of this one and a 4th on a jd.
I didn't see where i had already responded to it?
   / 1982 Ford F-1200 front diferential oil change? #7
I & T FO-44 shop manual not so pricey and not as much help covers the Ford 1200. It does not show the drain plugs on your model but the 1700 (same vintage) has three drain plugs, center section and the gear reduction housings on each end.
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
Mity-Lite 6ft Folding Leg Tables (A50325)
Mity-Lite 6ft...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
