Ford 753 BH flare fittings degree?
   / Ford 753 BH flare fittings degree? #11
Are you saying the the fitting on the pump (37* male JIC )is a size 14? Or that it measures 7/8" OD with 14 threads per inch.? Measure it and let us know
I really think you are confusing JIC 10 which measures 7/8" OD and has 14 threads per inch with JIC 14.
Surplus Center sell 3/4 hose with JIC 10 female swivels.
Yes, that's exactly it. It's a JIC #14 flare on a steel tube from the pump and BH valve. Then going into the loader valve it's a SAE 7/8"-14 ORP to a #14 JIC male flare. The #14 female to #12 male reducer will work perfect because now I can run all of my lines in JIC #12.
   / Ford 753 BH flare fittings degree? #13
:D I love it when a plan comes together... :D
   / Ford 753 BH flare fittings degree? #14
Ditto! He had me confused, JIC 14 and 7/8"-14 threads, as to which he had. Now that it's clear JIC 14. I agree the JIC 14 female to JIC 12 male adapter is the way to go.
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55302)
PENDING SELLER...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
