Oil over fill
   / Oil over fill #11
Heck, here in Vermont, that line on the dip stick is just a reference for the "hilly terrain" sump level. Down hill, it's low, up hill, it's high. There is always plenty of both! ;-)
   / Oil over fill
Thanks for the advice, always helpful.
   / Oil over fill #13
I just changed my oil and over filled it by about 1/2 inch on the dipstick, engine didn't sound right, made a little more noise, so I drained about 3 quarts out and began to refill, ended up with about a 1/2 quart left in a gallon jug, i have noticed i had some metal shavings in the drain pan after I poured the oil in the gallon jug, The drain pan was washed and dried before using, This was the first oil change (first50 hours) Is this normal or should I be concerned. I replaced the Original bobcat filter with a WIX, Maybe that's the problem....
   / Oil over fill #14
No, metal is not normal. I would save it and document it along with a call to the dealer and manufacture tomorrow.
Chris
   / Oil over fill #15
i have sometimes found oil shavings out of some sumps on initial chan ge / new equipment.
as i don't get alot of new equipment.. i don't see it often. :)
that's usually why I do an oil change within hours of buying new equipment.. in cast manufacturing junk was left in.
i will say that I find it mor ein trannies and rear ends than crank cases.
   / Oil over fill #16
Thanks for the feedback, Like I stated earlier, I didn't use the Bobcat brand filter, I went with a WIX, If the parts house gave me the wrong filter, would that have anything to do with the extra noise I was hearing, would the oil be restricted if the wrong oil filter was used? Thanks Pay1920
Claas Rollant 350 Round Baler (A50774)
Claas Rollant 350...
2012 Ram 3500 Crew Cab Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
1999 Case 1150G Crawler Tractor Dozer (A50322)
1999 Case 1150G...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
