That depends, if you are almost out and it is a dire situation then the manufacturer states it MAY be doneSpeaking of which, are you allowed to fold other than on the perforated edges?
I agree that in general it's not a good idea to drill holes in the ROPS, and I avoid drilling into the ROPS if at all possible; but I've drilled a couple of holes for 1/4-20 bolts, and the amount of material removed is next to nothing. If you're going to drill into your ROPS, use common sense and keep the holes to a minimum in number and size.
The lawyers are the prime reason for the "no drilling the ROPS" warnings from the manufacturers.
I drilled my rops to mount a couple Hella lights and the dealer had no issue when I traded it for a new tractor other than I had to leave the lights in place.
Good lord people get a grip, they will be printing instructions on toilet parer for some of you next!
I've noticed in quite a number of discussions on the TBN forum that it is a unanimous no-no to drill holes in ROPS tubing but rather accessories such as lights should be attached with other means such as u-bolts.
A comment above made a good point about stress. Any bending member has lower stress in the center. Drill the hole at the centerline of the member and it will have a minimal effect.
