new holland tractors which one in the 75hp range
   / new holland tractors which one in the 75hp range #1
case245
pa
kubota 7040sud
i looking at getting a 75hprse power tractor with fel 4x4 rops i dont want eletronic engine controls im looking at used i looked at a 75 td yesterday i liked the tractor i pasted on it it had eletricial problems
   / new holland tractors which one in the 75hp range #2
The new holland workmaster 75 has worked will for me. Had it just over a year and a half and just under 1500 hours with out many problems.
i want more tractor then i have i have a 70 hp kobuta the fel will lift 1970 ibs 800mm from the pins the 3pt 3307 24;; behind the pins i have the rear 16.9x30 loaded cast centers weights the specs on the workmaster look about the same as my kubota i was thinking t5000s i may have to go used as ii want to trade the kubota in
thanks for the reply
   / new holland tractors which one in the 75hp range #4
I have a TD75 4WD. It's a good basic tractor and the loader will lift over 2500 lbs. I also pull a 3X16 plow with it no problem.
How bad can electrical be? It's a simple system, a few safety switches, fuel solenoid, fuel heater, lights and instruments. If you can bargain the price down it should not be too difficult to fix electrical.
Sent from phone. Al.
it has 180 hrs on it no quik attach 33k there asking i told em thats to muc for 2003 tractor there not much grease in the loader to put in bushing in is a pia i cant weld to save the back side
   / new holland tractors which one in the 75hp range #6
Look at the new T4.75 Powerstar...you can get a brand new open station model 4x4 FEL powershuttle for $37,000
   / new holland tractors which one in the 75hp range #7
How can I get used new holland tractor 75hp to buy . I am in Nigeria and how much can it go?
   / new holland tractors which one in the 75hp range #8
The t4.75 has 3k lb lift capacity with the self leveling loader it also has a tier 3 engine with mechanical fuel system.
It's the same size as a M7040 but more lift capacity front and rear
You may be better off with a T5000 if you need a physically larger tractor.
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
