infrared heaters
   / infrared heaters #11
An infrared heater works best in an insulated room without a concrete floor. They are not for unfinished basements or garages. I have one in a 20' X 14' unheated breezeway, and it is quite toasty. They also do not beat you up on your electric bill. Used in the right environment and sized correctly, they are an excellent choice.
   / infrared heaters #12
ok im looking to replace my heat in garage it's metal building insulated well 30x40 i see the 6 element infrared heaters on sale for $158.00 suppose to heat 1500 square ft does anyone use these heaters and how efficent are they i have kerosene now but it just cost to much to heat thanks in advance for your imput.:confused:
There the biggest scam out there!! DONT buy one. 1500watts is 1500watts, just go buy one of those $20 heaters at walmart in the heater section, there 1500watts as well, which is the federal mandated maximum allowable wattage for a space heater.
   / infrared heaters #13
Tried the Walmart cheapos, they are junk. Infrared works great in the conditions I mentioned previously. Temp is the same on the floor as it is near the ceiling.
   / infrared heaters #14
Never seen a small electric that can heat that size space well. I have a 30x40 insulated metal building and have 115,000 btu propane ceiling unit mounted. It will take the building up 40 degrees in about a 1/2 hour.
   / infrared heaters
i put 1 of the infared heaters in my garage and it's insulated well but the heater ran all night and the next morning i went in the door i could barely tell any difrence it didn't work for me so back to the drawing board
   / infrared heaters #16
We were in the same boat, tried a bunch of different things and nothing really did a good job. Kerosene worked slowly, smelled, was in the way, and had to always haul fuel. Elec. - had to get an industrial type of unit - the shop was going to take 4 to really work and then I was going to be using a LOT of elec to run them. We dont have nat. gas (wish we did) so I got that larger (115K) industrial propane one I mentioned above. I think it was around $800 - yes it was not "cheap" BUT it works. I had a 500g propane tank put in (think it was $100 and they installed the tank and ran the lines to the heater, then I paid to fill the tank which I was to say is $2.80 or something like that a gallon).
The elec bill is nothing every month -like $15 on avg and that is my dusk to dawn lights, the power I used to work, the power for the fan on the heater, everything. I have a thermostat that keep the shop at about 42F all winter - keep my stuff from freezing and my diesel truck stays in there so it keeps it warm enough for easy starting without plugging it in. If I was to work in there I flip the heat on about an hour or so ahead of time and when I walk in I take my coat off and ALWAYS work in a tee shirt because it is 70 in there. The only thing is the floor itself and big steel items stay cold for a good long while until they adj. I don't recall how much gas the heater use but it is not too bad at all. Last year it cost me around $700 to heat it all year and I was in there A LOT!!!! Not like a night here and there I mean every weekend, most nights, and every other day I had off. May not be the cheapest way to do it but it really works great.
The other fellow that mentioned using a old house heater is also a good idea. In southern WV a used heatpump with back up elec should work well and be fairly inexpensive to run - plus you could get A/C for the summer which has it advantages!
   / infrared heaters #17
If this is in a shop why not get one of those cheap cast wood stoves from HF and some stove pipe and burn wood. Those throw heat and will bring it up to tmep in no time
   / infrared heaters
your right got all the wood i could ever burn thats what i heat my home but here the problem the center of the roof is like 20 foot high and insurance companys willnot insure it with just pipe going out the wall and i have no way of securing a flew that high wanted to do that few years back there no way i can put wood heat in wish there was i think code 54 has the solution i was just looking for a cheaper way or maby something i hadnot heard or seen that was out there
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
UNUSED TOY DIE-CAST REMOTE CONTROLLED EXCAVATOR (A54756)
UNUSED TOY...
