Blower chute acuator repair
   / Blower chute acuator repair #1
rasthai
Sask
MF GC2400
Actuator to elevate my blower (MF2360) now only works in one direction, is this possible to repair. If not I did see another thread that showed a possible generic actuator that could be used instead if anyone has info on that.
Thanks,
   / Blower chute acuator repair #2
Just wondering ,is your switch putting out power both ways possibly a broken wire or??? it seems kinda funny that it only powers one way.Have you checked to make sure it's not a electrical problem rather then the actuator itself.
I actually removed it from the machine and hooked it up to a 12 volt battery and it works with wires hooked up one way but if I reverse polarity does nothing. I was hoping it we a short between switch etc but with this result does not appear so or am I mistaken?
   / Blower chute acuator repair #4
Is the actuator a screw type? Some of those actuators have limit switches built in to the rear of them. See it it can a removable cover on the rear of the screw. My past experience with actuators is the limit switches can go bad and allow one direction. Most actuator are 12 - 18v dc. The mechanical limit switches prevents damaging from over extending.
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
Case IH Patriot 3250 (A50123)
Case IH Patriot...
KUBOTA ZD1211 (A53084)
