Ford 1900 wont start...electrical?
   / Ford 1900 wont start...electrical?
Good idea. I'll have a look tomorrow to see if the CA and CCA on my truck battery are comparible. If so, I'll use that to test.
Just seems odd that I had it running with no problems a couple of weeks ago, and a few days ago it wouldn't start.
I'll give that a try. Should be able to hold the voltmeter there while i jump it. Unfortunately, the headlights aren't working (on my list of things to fix). The wiring harness is a bit of a mess. If a dead battery can show a full charge, I'm starting to become more suspicious of that. I hadn't run it in a couple weeks and didn't disconnect the negative terminal the last time I shut down ( a disconnect switch is also on my list). The temps have been in the teens for the last couple of weeks at night, and the battery does appear to be at least a few years old...
   / Ford 1900 wont start...electrical? #13
If your battery is good and you still can't spin the starter I'd look towards corroded battery cables. Sometimes they can corrode up under the insulation and they still look good at the battery connection.
   / Ford 1900 wont start...electrical? #14
Did you get the replacement ignition switch from N/H. I don't think it has any thing to do with the problem you are having now. However if you used an aftermarket switch it may cause some other problems. If you need a schematic let me know.
Bill
I'll keep the battery leads in mind as I continue investigating.
The ignition switch I bought is a Shibaura SBA385200331. I bought it off ebay, but it seems to be an exact match.
I'll have limited time to work on it this week, but I will update the post after I do some more tinkering.
   / Ford 1900 wont start...electrical? #16
That is the right ignition switch.
Bill
Quick update: I pulled the battery and stopped by NAPA on my way home tonight. They bench tested it with both of their machines and said it's as good as the day it was sold. I put it back on the tractor, turned the key, still nothing. I jumped the starter and got a stronger spark than yesterday, but no spin. With the volt meter on the two large terminals on the starter, it reads 12V, when I jump across the + terminal to the small terminal next to it, the needle on the meter drops.
I'm going to carefully inspect all leads, grounds, terminals, etc. between the battery and starter next. After that, I'll pull the starter and solenoid.
   / Ford 1900 wont start...electrical? #18
I had a similar problem with my 1700 starter. I tested everything suggested and it came down to the small wire on the solenoid. The screw was not tight so the connection being loose cause the solenoid not to enguage. Look at the pictures in the link I am providing. This solenoil has a nut instead of a screw. Clean that terminal ,(the small one at the top) and make sure it is tight then try the starter again. http://www.tractorbynet.com/forums/...g/258752-ford-1700-not-turning-starter-2.html
If that doesn't work, check the switch on the clutch pedal to see if it is working. It is open circuit if clutch is not pushed down, and has continuity when the cluch is pushed down. That is a clutch safety.
Read the complete thread and posts. There is some good info about the starter in there and my 1700 4WD is almost identical to your 1900
I had a similar problem with my 1700 starter. I tested everything suggested and it came down to the small wire on the solenoid. The screw was not tight so the connection being loose cause the solenoid not to enguage. Look at the pictures in the link I am providing. This solenoil has a nut instead of a screw. Clean that terminal ,(the small one at the top) and make sure it is tight then try the starter again. http://www.tractorbynet.com/forums/new-holland-owning-operating/258752-ford-1700-not-turning-starter-2.html
Thanks, I read through and checked out the pics. I definitely appreciate the input and good info. I'll keep you all posted.
Eric
My nightly update...I tightend the small screw on the solenoid and cleaned the terminal its attached to. That didn't help anything. So, I grabbed a jumper cable hooked to the + battery terminal, then directly to the small terminal on the solenoid. This produces a lot of spark and the solenoid clicks but does not engage the starter. Hooking the jumper to the large lug gives a small spark, but the starter doesnt spin at all. This is all with the clutch pedal blocked down. What do we think?
Bill, regarding the replacement ignition switch I installed, I attempted to use that to start the tractor from the seat, just for kicks. Turning the key to the left and holding it heats the glow plugs as it should. Then turning to the right, past "ON", to "START" when I get to a certain point it will stay in the "START" position even when I take my hand off of it (just the same as it stays in the "ON" psotion when I take my hand off of it). Is this normal? I'm not sure if I'm turning it past where its intended to tunr to crank the motor over, and unfortunately I can't tell because I get no starter clicks or cranking using the key. Also, when I turn the key to the "ON" position, the light that comes on in tach is the same light as the glow plugs. Shouldn't the other light for the battery be coming on?
Thanks,
Eric
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
Exmark Zeroturn (RUNS) (A50774)
Exmark Zeroturn...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
