My Longevity Mig200S
   / My Longevity Mig200S #12
Much better audio quality!
And better editing(voiceovers).
So nice to be able to hear clearly.
I look foward to more of these better quailty videos.
   / My Longevity Mig200S #13
Thanks Dan, we will keep them coming!
Got home this afternoon and ended up building a new computer for BOL , But While windows was loading went out and played with a couple of pieces of tubing out of the scrap pile .
Above is before cleaning slag
These 2 were first and had welder a little to hot / high , was burning through the tube :ashamed:
This was after cleaning slag and getting adjustments a little better .
Have to for sure retool my brain from welding with my 110/120 lincoln to this welder . :ashamed:
Hopefully get to town in morning , want to pick up some rod to see if I can rekindle any brain cells from my high school days on stick welding . That could be Really entertaining !!;)
In my case it was " Stick " Welding . Strike , Stick , Break loose , Strike , Stick , Break loose , etc....... :cool:
Fred H.
My pictures Suck !! I can build computers from scratch , but trying to take a close-up without blurring , UGH !! :confused3:
If I take my time , set up every thing " Right " , ( Clean dust off glass of helmet also helps :ashamed: ) , I am still a hack , but am able to stick things together . Last weekends 5 minutes of play was the first welding done since last spring's Land Plane build , It comes around with time .
S.A. : I really Appreciate Your Help , Thoughts and Ideas , Makes Hacks Like me a better Welder or at Least Gives Me Hope .:thumbsup:
Fred H.
   / My Longevity Mig200S #17
Many digital cameras have a "macro" button that you push for focusing on picture close-ups or else you get blury pics. I imagine even some higher end phone cameras have the feature too. I would almost guarantee that the camera you are using does if the picture is blurry. My company's expensive high dollar camera that I must use at work absolutely will not take a close-up picture without blurring unless that "macro" button is pushed.
The Beauty of this Forum , Always Learning Something . Now going to have to research camera settings . :thumbsup:
Fred H
Well , Headed to town yesterday for some metal from my supplier . Couple of pieces of 1/4" plate and was also looking for some 1/4" square tube , maybe 2" x 2" but ended up getting a section of 2" x 5" or 2" x 6" , ( forget now ) what it was . Anyway , shot over to a welding supplier and picked up a 5# box of 6011 . Got home and ran 2 rods through the 200S . Welder works fine in arc mode , ( Meaning the MACHINE!! ) . Me on the other hand , ugh !:( . First mig welding requires 1 movement , Horizontal , But Stick / Arc requires 2 movements , Both Horizontal and Vertical , ( Feeding rod is the vertical movement ) . Sorry People , Way to much Strain on this Brain at this point in my life :confused2:. Did it years ago in high school but older now and Seriously Doubt Wiser , so I am reverting back to my favorite acronym ,
KISS , Keep it Simple Stupid . ( Stupid meaning me ):confused3: . 1 Movement easier than 2 , Likely Why I don't Chew Gum either . Never would be able to walk any were .:thumbsup:
Fred H.
P.S. Actually did better than I thought , never stuck the rod , Just Never burned more than 1" off the rod at a time either , So Shield Arc is right there also , " Moving to slow " .
   / My Longevity Mig200S #20
Fred;
Where are the pictures of your stick attempts?
Perhaps a seasoned pro could provide some constructive criticism.
It does not take 30yrs to lose the hang of stick welding... A year or two will do it also!
I guess I have gotten "spoiled" with MIG also
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
