seeking suggestions for tree removal...
   / seeking suggestions for tree removal... #21
If you don't want to use a chainsaw get an old cross cut saw, sharpened they do better than you think. My brother and I cut a cord of pulp wood with one once, but that is another story.
I appreciate all the suggestions and will undoubtedly end up using a combination of most of them...
Can't get a full size truck down there without scraping it up or cutting a wider trail...I mostly use a golf cart to get up and down...the tractor just barely makes it between trees etc...
The water level will not go down too much until late summer unless we have a really dry year...
I do have lots of heavy tow straps, chains and pulleys and I will take lots of pictures and post the progress
   / seeking suggestions for tree removal... #23
As someone suggested block and tackles can give you a tremendous mechanical advantage over that tree. Enough so that with enough pulleys and rope/cable, your golf cart could pull it out or at least up to shore so you can cut a chunk at a time in shallow water.
I do have a two double pulley blocks (makes a 4-part line) and 200' of 3/4 rope... before I had the tractor or the golf cart I used it (and several friends) to pull a much smaller tree from close to the same spot...
Now I just have to wait until it's warm enough to brave the cold water and put the suggestions into action...
BTW...this particular "fishing hole" has produced several rainbows in the 28"-30" range and a couple of browns slightly bigger...!
   / seeking suggestions for tree removal... #25
This is what I would do. I have to get into my creek all the time to cut up snags and yours is how they start, one long tree, then everything piles up against it. Before you know it the creek says,"I'm going around this thing" and cuts a new creek in my pasture.
Dump out your bar oil, & put Canola Oil in your chainsaw oil reservoir. The Canola works fine for bar lube while you cut the tree up and yes you can stick your bar under water(not the powerhead) and it will cut. When your all finished, dump out the Canola and replace with bar oil, then run the saw until the bar oil is back on the chain. Canola left in the saw for too long will congeal and clog the oil pump.
Curious.....why the canola oil?
   / seeking suggestions for tree removal... #26
Do you need any help removing that tree?
:laughing:
   / seeking suggestions for tree removal... #28
   / seeking suggestions for tree removal... #29
Oh you environmentalists!!!! Just kidding......that makes sense...thanks!
With a 4x1 mechanical advantage (2 snatch blocks) your tractor will snake that out of there in one piece. Might have to cut the root ball off first though. I have yanked trees that size out of bottoms using nothing but my F150 2X. Of course my wood hauler always has 4 snatch blocks, around 400' of cable in 50-75' lentghts, some tow straps, etc. The draw back to adding ma is the amount of cable you need, i.e., for a 4 to 1 ma, you have to pull 40' of cable to move the load 10'.
Harry K
   / seeking suggestions for tree removal... #30
Classified Ad;
Free firewood, you remove!:laughing:
Or a reeallyy looong bar for your saw!
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
Woods BB72 6' 3pt. Rotary Mower (A50775)
Woods BB72 6' 3pt...
Galvanized Livestock Gates - (6x Total Gates) (A55301)
Galvanized...
2022 Chevrolet Tahoe SUV (A55758)
2022 Chevrolet...
