Dump trailer, Finally decided what I am buying.
   / Dump trailer, Finally decided what I am buying. #1
BIG DOOLEY
MICHIGAN
JOHN DEERE 2320
After 3-4 weeks of shopping on the net and making many phone calls I put a deposit on a dump trailer.
I wanted a dump trailer with slide out ramps tucked away underneath the bed.
Many have located the ramps on the side of the trailer for numerous reasons.
Sure-Trac HD Low Profile trailer was my choice.
I found a leftover 2012 model and saved some cash.
It is 82" x 12'
16" on center bed support
Combination tail gate
LED lighting
Powder coat finish
Adjustable pintle ring
Slots for 2" x 12" side board extensions
12,000# GVWR (2 x 6000# axles)
I am going to get the spare tire also from the dealer.
Gave the dealer a deposit over the phone and will probably pick it up next Friday.
We are due for a storm tonight and the roads will be bad tomorrow.
   / Dump trailer, Finally decided what I am buying. #2
That's a nice looking trailer. I've always wanted one, but just don't have a use for it. How did you decide on the 12 footer and not the 10 or 16?
   / Dump trailer, Finally decided what I am buying. #3
Congratulations, looks like nice trailer. When I was looking I found two trailers a Big Tex 14k 6.5x14' and a PJ 14k 6.5x14' wound up with the PJ trailer and it has the rear slide out ramps too. This was a 3 yr old trailer that the local rental store had not been able to rent out more than 5 times powdercoat was still like new in the bed. Been a good trailer, hope your s works out as well.
   / Dump trailer, Finally decided what I am buying. #4
Nice trailer.I bought a good used 1 about 6 mo ago and love it. Mine is a tow master brand with 2 7 k axles.It had surge brakes. I just finished (today) converting it to elec. brakes.You will find many uses for it.I have
Thanks everyone.
I wanted one large enough to hold my tractor, move furniture and be able to haul 5 yard loads.
I measured my tractor with loader and rear blade.
12 foot will hold my tractor with the FEL elevated up over the front tarp holder.
The low sidewall/tailgate height will let the rear doors close with the rear blade on the 3 point elevated out the back of the trailer if needed.
I will store my ballast box at the woods and use it with the FEL/grapple when cutting firewood.
14' or 16' foot would be a little better fit but too long for my needs, too hard to manuver it the woods and too large to store .
My crewcab is 23 feet long plus a 12' foot trailer will be hard enought to manuver in the woods.
I made a pintle hitch for the tractor so I can move the trailer about in the woods.
The 12 foot will also hold enough shingles when I re-roof in a few rears also.
I think it will be the perfect size for my needs and will be smaller to store.
I wouldn't mind having a storage tent for it or building a small second garage out back after I retire.
   / Dump trailer, Finally decided what I am buying. #6
Nice looking rig! Like those shiney wheels.
What does one these babies cost roughly?
   / Dump trailer, Finally decided what I am buying. #7
Where is the hyd pump / tank and battery located ?? I didn't get a tarp with mine
Thanks
The photo is off the net.
Mine won't have alumimnum wheels.
Otherwise the same.
They will be white spoke wheels 16" x 8 lug.
Trailer, tax, title and plate was $5915.
I have to drive about 1 hour to pick it up.
The box in front of the bed hold the battery, reservoir and pump
   / Dump trailer, Finally decided what I am buying. #10
It's a beauty. I have been lucky to borrow one. I like the size of your. Must have a large truck to handle this.
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
2004 PROCO 130 BBL VACUUM TANK TRAILER (A52472)
2004 PROCO 130 BBL...
2021 New Holland C327 Compact Track Loader (A53472)
2021 New Holland...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
