AC D14 Mysterious Fluid Leak
   / AC D14 Mysterious Fluid Leak #1
mattnice
Lawrenceburg, TN
~1959 Allis Chalmers
There is this moist area on the right side of my AC D14 at the area you can see in the pic. I have recently purchased this tractor and have not given it a bath yet, so I do not know if it actually is progressively getting worse or actively leaking. Just wondering where I should start on troubleshooting, what it could be, and if I should be concerned? The tractor starts and runs great. Thanks.
   / AC D14 Mysterious Fluid Leak #2
Guessing that is the hydraulic fill cap, and probably behind that sheet metal is where part of the hydraulic system is. Possibly a connection weeping. Pull the side panels, and look for washed areas where oil may have leaked.
   / AC D14 Mysterious Fluid Leak #3
Looks like there is reservior breather there. Make sure it's not clogged,
   / AC D14 Mysterious Fluid Leak #4
Those old iron tractors tended to have some minor leaking at the seams. I would look behind the panel to see if something was loose but unless it is really leaking badly in like a puddle under the tractor after parking or if it leaks worse when running , I wouldn't worry too much about it, just top up the oil occasionally.
   / AC D14 Mysterious Fluid Leak #5
Looks like a drain plug there? Maybe leaking from that? don-ohio :confused:
   / AC D14 Mysterious Fluid Leak #6
With that dark ring around the bolt by the fill port, I believe that is what is leaking. check it for tightness and if loose, I would remove it and put a little pipe dope on it and reinstall. Threads do wear after years of use and
vibration. Just my :2cents: for today. Let us know what you find.
Tom
Carnival Ticket Booth (A51691)
Carnival Ticket...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
