Rotary Cutter How do I ream out hardened steel?
   / How do I ream out hardened steel? #1
jrchafin
Mahinda 7520
Hey folks. I have a 5' bush hog with a shear bolt. The input shaft of the gear box only has a 3/8" hole, not 1/2" like every other one I've seen. I break this shear bolt fairly often, and I'm quite sick of it. Especially since I have a slip clutch as well, so the bolt really isn't necessary. Unfortunately it is not a splined input shaft. So I would like to ream this hole out so I can put in a grade 8 1/2" bolt and hopefully never break it again. Obviously I can't do this with a regular drill bit. What is the best way? Should I use abrasives and a die grinder? Carbide drill bit?
   / How do I ream out hardened steel? #2
Carbide is brittle so unless you could get this shaft into a drill press I doubt you could keep from breaking the bit.
Wouldn't it be easier to adjust the slip clutch so it slips?
   / How do I ream out hardened steel? #3
I would tend to agree, that you should be working on the slip clutch not the backup bolt.. You do know you have to adjust and test the slip clutch at least every season right? Lets say you do ream out the hole in the input shaft and put a nice grade 8 1/2 inch bolt in there and now you hit a stump. is that rusted slip clutch going to slip, or are you going to have a nice repair bill on your PTO components of the tractor.. Lets see if some other more experienced guys than I weigh in here, but these are my first thoughts.. I think you are headed down a dangerous road.
James K0UA
   / How do I ream out hardened steel? #4
it you Walt apsalutly to drill go Wotherspoon ciment car éloges bit and shrapnel Wotherspoon silicone câblée Stoneham Luke a normal bit but i not récompense berceuse next you Blake thé gearbox shaft and then big problem. work on the clutch instead and put a good grade five bolt . make sure no play with the bolt and shaft.better is to get a key way machined......good luck
   / How do I ream out hardened steel? #5
If you are breaking a grade 8 3/8" bolt frequently, I don't think I would have an issue with drilling out the hole for a bit larger bolt especially since you have a slip clutch, but I think I would go up in steps to a 1/2" grade 5 rather than an 8 and see if that fixes your problem. I have to agree with you that a 3/8" shear bolt is not adequate for the new PTO switches that slam everything into gear without being able to feather it in with the clutch. You do need to loosen off the bolts on your slip clutch to make sure it will spin and is not rusted together, then retighten to where it only slips briefly when engaged or under super heavy load.
As for drilling the hole, a normal HSS bit with titanium oxide coating should drill thru that shaft easily enough if you go slow and use a cooling fluid on the bit. If not, go with a cobalt bit but again the secret is to go slow and make sure the shaft doesn't try to rotate and bind the bit because it will snap easily if it does.
Yeah, the slip clutch is fine. I think a big part of the problem is the drive shaft is made for a 1/2" bolt and the gear box input shaft 3/8, which means the bolt gets slammed repeatedly by the yoke of the driveshaft and breaks needlessly. For folks warning me about putting too big a bolt, most of the time these are put together with splined shafts, which I would gladly change to if I could easily. There is absolutely no need for a shear bolt in this setup.
I can't drill this with a titanium or HSS drill bit, I've tried. Might as well try drilling a diamond.
   / How do I ream out hardened steel? #7
See from your last post you have in fact determined the shaft is hardened. You will need something tougher than an HHS bit. I'd try either a cobalt or carbide bit. In addition since you are likely going to be do this sorta free hand is to use a drill bit with a pilot to help guide and keep the bit from wondering around. trying to do a decent job on a round rod/shaft is very difficult without something to hold the bit in place. A pilot will do that.
   / How do I ream out hardened steel? #8
Like others have said on here. I'd work on your clutch, your shear bolt is to protect you equipment. Beef it up and something bigger breaks.
   / How do I ream out hardened steel? #9
so.. you have a smooth input shaft mower with a 3/8 hole.
and you have a slip clutch made for said smooth shaft.. but with a 1/2" hole?
the movement of the 1/2 hole ont he 3/8 bolt is cutting it.
i think I'd drill a 3/8 hole perp to the 1/2 hole so you can use it on either.. before I'd deface the mower gearbox imput shaft. slip clutch is cheaper and easier to rremove to setup to drill.
   / How do I ream out hardened steel? #10
Now that sounds like an idea to me, and you can get the coupling off and put it in a drill press where you can get things lined up and steady, and be a heck of a lot easier to drill. the only other thing I could think of was to try to get some thin bushing to go over the 3/8 bolt to fill the gap in the 1/2 inch hole in the coupling. But I like your idea better.
James K0UA
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 JOHN DEERE 524L LOADER (A51242)
2021 JOHN DEERE...
2012 RAM 3500 (A50323)
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
