Kubota M9540 or New Holland T5050???
   / Kubota M9540 or New Holland T5050??? #51
Impressive that explains why they look a lot wider and taller sidewall than my 12.4 R24's on mine. Its because they are :D Should be good with that loader in soft ground
Yeah I hope this tractor turns out to be a real workhorse. She looks impressive just hope her work ethic matches her looks :)
   / Kubota M9540 or New Holland T5050??? #53
Congrats!
Not trying to hijak the thread, but the M9540 that I checked out at Marshall Machinery in PA, was a total POS. More things broken than working. I will NOT go there again as the salesman basically lied to me over the phone and I wasted about $200 in fuel and a full day.
Going to check out a M9540 open station in Ohio Monday with 2000 hours, 1353 loader 12 speed and 2 remotes.. Looks to have had a much easier life. It is at a green dealership and they said it is a local 1 owner trade in... $24K
Jonathan
Good luck on the 9540 I hope this one turns out to be a better tractor for you. When I looked at the 9540 it looked to be a well made tractor. I personally like the cab a little better on the T5050 though.
   / Kubota M9540 or New Holland T5050??? #55
Yeah cab is out of my budget.. I wasn't planning on getting a loader either (I have one on my MX5100) But this one in Ohio comes with a loader which is even better as it is 4X4 and a heavier capacity loader, and it is bobcat style QT which should be the same as my MX5100, and so it will fit the bucket I have and my homemade forks...
Jonathan
   / Kubota M9540 or New Holland T5050??? #56
Congrats on the tractor...
   / Kubota M9540 or New Holland T5050??? #57
Jonathan
The 1353 is a monster it has 1000lbs more lift capacity than the one on the 5100 plus a bunch more lift height. I can off load 3000 lbs pallets from a semi truck. Hope it works out for you and that your homemade forks are seriously over built for the mx5100 because the breakout force on the 1353 is 4900 lbs 800mm forward of the piviot hope this one works out for you
Dave
   / Kubota M9540 or New Holland T5050??? #59
Will that tractor go up Carl's hill ?
   / Kubota M9540 or New Holland T5050??? #60
If you put some green paint on for traction it shouldn't be a problem :)
The only hill I've ever had a hard time climbing or pulling something up was a mixture of solid ice and hard pack snow on a gravel road.
Dave
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
