Support for Chainfall.
   / Support for Chainfall.
BTW, this leanto is already built. Probably about 25 years ago. It has plywood sheathing on the roof with a steel panel roof.
I can't add an additional rafters easily and can't build anything on top of the rafters.
I want to safely be able to lift a max of 1000 pounds with either a chainfall or an electric motorized cable hoist.
My research tells me that 1.25" schedule 40 pipe will be strong enough for a 24" span. I just need to determine an appropriate way to attach it and determine if some upgrade is needed for the rafters that I can afford and can do myself.
   / Support for Chainfall. #12
I would sister the rafter all the way - wall to wall, with 1/2 ply glued and screwed in between. Then I would repeat the same on the next rafter. Finally, I would install two rows of blocking the full length on the lean to. You wouldn't have to use 2x12 for the blocking, I wouldn't use less then 2x8.
The blocking will transfer the load onto adjacent rafters - past your pipe.
As a "safety", string a mason line taught wall to wall at the bottom edge of a rafter. Tap a nail in as a reference point into the rafter, under the mason line. When applying a load, keep you eye on the line. If the nail separates from the line more than say 1/2"-3/4", you have reached your "pucker factor load limit" :)
   / Support for Chainfall. #13
I agree - sister it all the way. if you dont- you are just adding more dead weight. blocking is a great idea - similar to building a beam to go across a few rafters.
Ok, what you say makes sense. I'll do it the way you suggested. Thanks very much.
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
1042 (A50459)
1042 (A50459)
John Deere 922 Platform (A50514)
John Deere 922...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
