F350 running problems
   / F350 running problems #22
   / F350 running problems #23
cheap insurance.
now that we have on ein the GB.. it won't ever fail.. :)
Ain't that the way? I won't be disappointed if I never have to change it. :wrench:
   / F350 running problems #24
There is a possibility that the IDM (Injector Drive Module) is going bad. Or possibly the Wire harnesses under the valve covers are having problems. Just a couple more problems that the Ford diesels have... Along with numerous other problems.....
   / F350 running problems #25
Replaced cam sensor, didn't help problem at all. It seems like it will run until something gets hot in there. It won't completely die, just wont' take the diesel. Can pull over and let it sit for about 5 minutes, then it will run ok. It's like something in there has to cool off. Any other suggestions?
MY 99 7.3 would die at 50mph and up and slow and slugish at 35mph.cleaned the screens hiden inside the round white barrel above the tank pickup to fix the starving fuel problem. Drop the tank or lift the bed. It takes a special tool from autozone to remove the two fuel lines on top of the tank.Unscrew the big plastic cap to get to the pickup. The pump is under cab in the frame.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
