Ford vs chevy vs dodge
   / Ford vs chevy vs dodge #11
Why does it HAVE to be Ford,vs.Chevy,vs. Dodge? They're ALL good trucks......they'll ALL take a beating and keep on ticking.
Pick the one you like on a test drive,as long as it has heavy duty frame, suspension,brakes, and wheels.
Just about anything that's used will require a minimal amount of fixing little things. Get a truck expert to drive it and then if it falls apart,you can blame him/her!! LOL! don-ohio :)^)
   / Ford vs chevy vs dodge #12
I would say avoid gm 05 & older cause of injector issue. Gm 06 & 07.5 were awesome trucks and the gm dmax engine before the clean emmission diesel 07.5 & later.
I would say avoid any 6.0 ford, but if you can find a good shape 7.3 they were build to last.
The 5.9 cummins is an awesome engine. But i am not a fan of 4 soeed trans, and I have heard rhey are on the weak side when stock, but a good after market trans kit csn make it bulletproof..
   / Ford vs chevy vs dodge #13
Skip the junk and buy a Toyota unless you like paying a shop $$$
   / Ford vs chevy vs dodge #14
I've worked on my '04 powerstroke several times. Although it looks like there is very little room to work under the hood once you remove all the routing for the turbo there is much more room than you think. It takes maybe 10-15 minutes tops for me to pull all the boot hoses and fittings out. The air flows from the fresh air intake through the radiator and then back to the engine. I suspect that the other diesels are the same way.
I have replaced the thermostat and cleaned the EGR valve. I didn't have to remove all the turbo piping but I ended up finding a hole in one of the hoses that was causing me to lose boost.
I wouldn't be scared of any Dodge from the early to mid-2000's or Chevy/Duramax. If you decide to go with a ford just get ready to replace the engine oil cooler and a few other known items like the EGR cooler at about 90-120K miles. It's about a ~$2K job if you hire it out. They all have their problems, most are well known.
Good luck and keep us updated on what you find.
I own a 2007 5.9 Cummins.I didn't buy a 2007.5 6.7 L because, this is the 1 st of emissions and they had problems. I think those problems were solved in the later yrs. With the 5.9.I have tons of room under hood to be able to work on if any problems were to arise. The 6.7 L Cummins doesn't have much room under the hood due to all the emissions crap. The D.max & Ford have little to no room under the hood.Not sure which year it started,but with Ford the cab has to be removed to be able to do some work on the engine.Some will say that Dodge has Tranny problems. I have 98K on mine and have never had any issues.Except brakes & tires
Fi-Q, thank you. That's the info I was looking for.
Toyota???.... Really???? Didn't even know they could pull that much.
   / Ford vs chevy vs dodge #16
Yeah, didn't you see them pulling the Space shuttle with one?
Don't know how much you are planning to pull, but I was very surprised ay how much an F150 can pull these days. Over 11000 with the right package! I just ordered one rated for over 9000 after considering a 250. After seeing the cost of ownership of the bigger truck, I went with the F150 since I'm only towing stuff a few times a year.
My family and friends (and even me to some degree) all work for GM but after years of ongoing troubles with my Acadia, they do not deserve my $$$.
   / Ford vs chevy vs dodge #17
04-05 dodge 5.9 with 6 speed manual.
325hp and 600ft.lb is plenty, leave it stock exept an exhaust and quality air filter.
The auto is terrible unless you have 3k to invest in the tranny.
The 4x4's eat ball joints and tires the 2wd is lower maintenance and gets better gas mileage.
If I were looking this is what I would be scouting for.
   / Ford vs chevy vs dodge #18
We purchased a DuraMax 2500. Never Again. We had injector issues @ 90K. This Pickup was maintained well, and never pushed. Cummins is probably the way to go. I never cared for Chevy's interior. Seems blocky, and just not very refined. I like Ford and Dodge (I have a Ram1500 now). If you decide on a Chevy, ask for a deep discount...you paid for it in fed. taxes already :).
   / Ford vs chevy vs dodge #19
Well, you can hear it from someone that owns 1. 98 K and have had no problems. Mine is stock.Problems usually start when you add xtra power without up grading the tranny.They aren't built to handle xtra HP without an upgrade.You may want to look at a gasser instead of diesel unless,you tow a good amount of weight
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
