Diesel Wear Scar test limits - Canada vs. USA
   / Diesel Wear Scar test limits - Canada vs. USA #1
3930dave
Super Star Member
Canada
Ford 3930
Came across this recently,
Bosch - Why Diesel Fuel Injectors Fail - Diesel Power Magazine
Sounds like the Lubricity test limits for diesel fuel are slightly different.
"The maximum allowable wear scar in the United States is 520 microns (460 microns in Canada)."
I did not know that..... thought I'd share ! Haven't tracked down the actual govt regs, but at this point I'll run with the assumption that DieselPower verified this statement, before publishing.
Good general article on diesel injectors, and their failure modes.
(P.S. - I linked to page 2, where I took that quote. Bottom of the page gets you back to page 1, if you want to read the whole article).
Rgds, D.
   / Diesel Wear Scar test limits - Canada vs. USA #2
There has been many discussion on this issue on the Volkswagen "TDI" forum. Some TDI owners have had their "high pressure fuel pump" HPFP failing prematurely apparently cause by a lack of lubricity in the fuel. The percentage of failure is much much higher in the USA compare to Canada. From the research some members of TDI did, Canadian diesel doe's have better lubricity compare to US.
   / Diesel Wear Scar test limits - Canada vs. USA #3
And cutting diesel with kero is one of the worst things that can be done. It is used as a cutting agent, not good for injector pumps.
   / Diesel Wear Scar test limits - Canada vs. USA #4
Agree!
Interesting datapoint Henri. % wise, those limits don't seem that far apart; it would interesting to see the studies that were done to create the Canadian limit.
From the time I purchased my used diesels, I always have added a fuel additive. I saw enough data at the time to convince me that it would be a good idea, and the subsequent field reports agree.
This article caught my eye, 1) because you don't see the govt #'s quoted often, and 2) I didn't realize there was a border based difference.
Rgds, D.
   / Diesel Wear Scar test limits - Canada vs. USA #6
Rgds, D.
I had heard that diesel in the USA is cut with Kero for the winter blend, if they still do this, that is why the difference between CDN and USA diesel.
Ahhh.... now I'm with you Will. I was thinking you meant an individual (vehicle owner) adding Kero, got it !
Could be - seems a lot of this industry runs on whatever is the most expedient/profitable for the oil Co's - if that means your IP, etc. goes out early.... Oh Well :cool: !
Caveat Emptor.
Rgds, D.
This is a little bit of PR from a company promoting Biodiesel and is a few years old but it's still worth reading.
http://oxytane.com/mystery/Liquid%20fuels/Lubricity%20Bulletin79.pdf
You're welcome CB.
Al - thanks for that pdf. Great snapshot of the history of this issue, and likely explains where the Canadian threshold came from (the Engine Manufacturers Association).
A lot of people may not realize that Big Oil won over the Engine Manufacturers (in the USA) - no wonder this information is somewhat obscure.
Biodiesel is generally recognized for good lubrication properties.
My concerns with Bdiesel are:
1) Consistent quality. This will hopefully stabilize as the sector matures. Another thread I've been in on here demonstrated that certain areas of the USA have Biodiesel commonly available in fairly high percentages, and that most of the volume users recently have had good results. There does seem to be a critical mass aspect in a given geography to getting the consistency right.
2) Pump level labeling that very clearly communicates the Bdiesel % present.
3) Solvent action. If you take an old diesel like mine, run the tank almost empty, then throw in a load of B50 Biodiesel...... chances are I'll be changing a fuel filter Real Soon ! I can do that, but it is something I'd rather not do when taking a vacation or a critical business trip.
Potentially a PITA for me, but nothing compared to a newer diesel - a plugged filter in that case can mean you are buying a new Injector Pump :shocked: :cryingeyesout: !!!
Rgds, D.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2017 Ford F-250 Reading Service Truck (A55852)
2017 Ford F-250...
2014 Ford Mustang Coupe (A55853)
2014 Ford Mustang...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
