Warn XT30, Vantage 3000-s or ProVantage 3500-s?
   / Warn XT30, Vantage 3000-s or ProVantage 3500-s? #1
Rod1
Member
Colombia
N/A
Hi, everybody.
Which are the differences between Warn winches XT30, Vantage 3000-s and ProVantage 3500-s? Aside from 500 lb more for the last one, of course.
Which one would be the best for an RTV900?
I will use the RTV on very steep clayish hills at high altitude (5000 to 8500 ft).
Thanks for the input.
   / Warn XT30, Vantage 3000-s or ProVantage 3500-s? #2
Hi, everybody.
Warn Industries - How to choose the right winch
From the q/a section on the link above:
Q:
"I am looking at putting a warn winch on my new Honda 420PG. (2500 lbs) My Question is what is the difference between a ProVantage winch to the RT Or XT. Does the pro also have a 3 stage planetary gear train like the XT or RT. Is it a cheaper "newer" design or does it replace the XT and RT. Confuse!
A:
"All of our powersports winches have the three-stage planetary geartrain. The ProVantage winches are the newest models, and are replacing the XT/RT lineup. In addition, we have added the Vantage line, which has a more affordable price. "
   / Warn XT30, Vantage 3000-s or ProVantage 3500-s? #3
The Pro vantage has better parts in it, probly has a better warranty. I have 3 warn winches, a m 8000 on my jeep, tabor 12000 on my silverado, and a xt 30 on my crew ranger, usually, with warn, the cheaper winches have less warranty. I think for your Rtv you would be better off with a 4000 or 4500 # warn winch, if you plan on winching alot. RTVs are heavy. The xt 30 at 3000 #'s was minimal for my ranger crew. It works okay, but the dealer had it stock at the time and I didnt want to wait for the 4000# winch which was on backorder. People wil disagree on this, but a good rule of thumb is you need a winch at least 2 the weight of the rig its going on. My theory is by the biggest you can afford:D. You can always get a snatch block to double that also. They will make it easier on the winch. LUTT
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56436)
LIKE NEW 2023...
