Are mower deck wheels necessary?
/ Are mower deck wheels necessary? #1
CJBOTA
Gold Member
Salem, Ohio
Kubota B2620 & MX5100
I have a b2620 with 150 hours on it and all of the anti scalp wheels have fallen off of the mower deck. The front two broke clean at the joint. (poorly welded joint) the back ones gave up because the bracket material thickness is less the 1/16" thick. I bought a $14000 lawn mower hoping I would get something that was heavy duty. I am happy with the tractor, but I feel the mower deck is a piece of crap.
Anyway my question is, are the wheels really needed? If so I am going to fabricate heavier brackets but that is going to be a lot of work. My dealer isn't interested in helping me, "they have never experienced this problem before" .They are really nice people so I really don't want to fight with them, I just want to fix my deck. I figure the Japanese (Kubota) are a little like Germans if you try to tell them there is something flawed with their design. What is funny about this is I mowed the same grass with a cub cadet 3205 for 10 years and never broke a wheel.
Your opinions on the necessessity of the wheels would be appreciated, thanks!
Cj
/ Are mower deck wheels necessary? #2
Personally if I was in your shoes I would try to find a way to beef up those brackets and put the wheels back on...
I have not hear of the happening to anyone else on here...
Perhaps someone else with this issue will pop in to give advice...
Kubota makes very good tractors and implements...
I find this somewhat uncharacteristic of their quality...
/ Are mower deck wheels necessary? #3
You could leave the wheels off and weld 1/2" steel plates where the wheels are now located. That way they should operate like little grader blades and level the dirt/yard down where with wheels the deck would just lift up and down with the contour of your yard.
I've never had a Cub Cadet before to compare decks but I have had several Kubota decks and have actually used several of them to push stuff and level out high spots of dirt and never had a problem with their not being rather heavy duty.
I did have a RFM (Jolliee brand?) made in France at one time and it kept falling apart. I gave it back to the dealer and got a Landpride deck that was built like a tank and was almost as heavy, never broke it. The cheap one was $1200 and the Landpride was $1700 so I guess for the money difference one was considerably more durable. I'm fairly rough on mowing/leveling decks was in my earlier years of trying to dominate my land. I've got most of those high spots mowed/graded down now but I'm still having trouble mowing the tops down on several big limestone rocks. My brother (next door) always tells me he heard me mowing the rocks on my lot after I finish mowing.
One other thing, some decks use their wheels to only touch the ground when there is a high spot to keep from grading instead of mowing. My F model Kubotas have the deck out front with bigger heavy duty wheels that ride on the ground all the time unless I lift the deck up on purpose.
Turby,
I also own a Mx5100 with a backhoe and I agree that normally things seem well built. I had the platform on a bx2350 break in half a few years ago but Kubota did fix that under warranty. My wife was using the mower when the first one came off so I just figured she hit something. After I yelled at her about a week later i was mowing and the other one fell off. When I looked at the weld joint I was shocked to see there was no fusion whatsoever between the deck and the bracket. The joint looked like a piece of bubble gum was connecting the two parts. Correctly welded joints should be as strong as the parent materials. In other words it should not break clean, it should be like torn apart. The worst part about the front ones falling off was the fact they went under the deck and damaged the mower blades.
Johnthomas,
I am glad you weighed in on this post because I know you have experienced a lot of different equipment. You are right about using the deck as a dozer as I have done the same thing. So I was wrong to imply the entire deck is a piece of crap. Just the anti scalp wheel brackets or the welding of them is crap. I like your idea of skids vs wheels, that's what they put on my king kutter tiller.
/ Are mower deck wheels necessary? #6
Okay. But when you said, "the mower deck is a piece of crap", you cannot later refer to it as only being implied. ;)
I understand your frustration. :thumbsup:
/ Are mower deck wheels necessary? #7
CJBOTA
I can't understand why your selling dealer would not help you on this. Your deck should be covered under warranty. :confused3:
/ Are mower deck wheels necessary? #8
How long have you been using this deck? A friend of mine has a similiar kubota deck and it rusted through in several places but that was after 10 years of heavy use.
I think the fact that they broke off means you need them. Were the wheels smaller than the ones on the cadet?
Ok, I stand corrected, I was wrong to say the whole mower deck is a piece of crap, just part of it is a piece of crap. I just bought the mower this spring, so it is not a year old yet. We do mow a lot. We do three yards that add up to almost 20 acres. I now kind of wish I would have bought one of those F series like johnthomas had for a while. Maybe I will go that direction next year. The reason I went with the b2620 was so I had a smaller tractor to maintain our 1 acre strawberry patch. It fits between the rows much better then the mx5100. I guess the reason my dealer won't warrant it is because I am the only one that ever experienced this problem. I really don't think that is a good reason, but like I said they are good people so I really don't want to argue with them. I am going to try it for awhile without the wheels to see how it goes. The cub cadet deck was a different design. It was not suspended, the wheels supported the deck. I still have the cub but it is only a 48" deck.
/ Are mower deck wheels necessary? #10
Sorry to hear this, as I'm in the market for a new mower.
I have a Simplicity Regent and about 3 acres of flat grass,
but with holes EVERYWHERE. The wheels kept falling into
holes and breaking the first year, and the next year the
wheels, brackets and all, started breaking off the deck.
I got fed up rewelding them and made adjustable spring
hangars for the two front wheels and hung the deck from
the frame. Works remarkably well (I adjusted the height
right where I wanted it).
So the answer to the original question is, No you do NOT
need wheels on your mower deck.
/ Are mower deck wheels necessary? #11
Why don't you fix your yard? I have put a 175 hours on my conquest with no problems at all. Welcome to TBN
/ Are mower deck wheels necessary? #12
Well, it's 3 acres worth of grass, with moles, gophers, and the neighbor dogs constantly digging holes.
Thousands of holes! I don't live in suburbia, I live in the country, and I don't manicure the lawn.
Anyway, I haven't seen a mower deck that looks like it could take the punishment of my holy property.
They are only cheap thin steel, all of them.
But, that's not the point. The point is, that any mower deck can be hung from the frame if done
properly and you can saw off the front wheels AND brackets and never be bothered with them again.
I think that was the original question, Are mower deck wheels really necessary?
/ Are mower deck wheels necessary? #13
It depends on what you are using the deck for. :laughing:
Warning do not engage the PTO.:thumbdown:
/ Are mower deck wheels necessary? #14
I read the post and it reminded of my uncle, i came in one afternoon and he said i fixed my mower today, i said what did you do and he showed me. he drilled a hole on each side of the deck and installed a threaded rod on each side of the deck and atached to the foot pad on each side, the wheels were gone i looked at the grass it was 2 inches in some places and 4 inches in others. if it works for you it works for me
/ Are mower deck wheels necessary? #15
Usually the mower deck hangs from the tractor and the wheels just help float over the high spots . Have you got yours set to carry the full weight of the deck all the time while mowing ? They probably won't take that . Iam not familiar with your tractor or terrain , just thinking out loud .
/ Are mower deck wheels necessary? #16
I have at least 5 acres of pasture, Take the wheels off and just use the back rollers.
/ Are mower deck wheels necessary? #17
I have a Simplicity Regent. The mower deck has (had) 4 wheels. There is an adjustment lever that adjusts
the height of the deck, you adjust the height, then adjust the front wheels to maintain that level on the front
of the deck. In operation, both front wheels were constantly dropping in holes, and the cheap plastic broke
into pieces. The left rear wheel dropped into a hole and broke not only the wheel, but the bracket that held
the wheel, I welded it, It broke again. The right front bracket broke, I welded it, it broke again.
Your suggestion to take off the wheels was the first thing I tried.
The front of the deck hung down too low though.
Then I built hangers to hang the front of the deck from the frame
and I adjusted it right where I wanted it, and I get a consistently
level, perfect lawn every time. No wheels to drop in holes,
no brackets to break off of the deck.
/ Are mower deck wheels necessary? #18
My front wheels rarely touched the ground, The pond once but that's a different storey. if it works for you go for it.
/ Are mower deck wheels necessary? #19
You and I have a completely different deck.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
HUSTLER RAPTOR SD ZERO TURN LAWNMOWER (A60430)
HUSTLER RAPTOR SD...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
