Welding helmet advice for a farmer
   / Welding helmet advice for a farmer #1
psu927
Member
Do a fair amount of stick welding here around the farm. Been using dads old helmet for 10 years and its shot. Glass is broken, lense foggy, cracked, etc... time for a new one. Are the auto darkening ones worth the money? I really want to keep it under 130 bucks or so. Should i just go with a good old cheap head nodder? Thanks fellas
   / Welding helmet advice for a farmer #2
I like my harbor freight auto darkening helmet. Less than $50 with the coupon. Wouldn't want one if I welded all day but it meets the requirements for this part time farmer and occasional welder.
   / Welding helmet advice for a farmer #3
I used a regular helmet for 40 years about. Then I was in HF a couple years ago and they had an auto darkening helmet for $39 and that was cheap enough where if it didn't work I could just throw it away. But it works like a charm.
I still have both helmets but the auto is always my first choice. I understand the auto's don't work well when it gets very cold out. They have more expensive ones out there no doubt, but I am just a hack welder on little project like maybe small trailers or carts or things small.
   / Welding helmet advice for a farmer #4
   / Welding helmet advice for a farmer #5
Times two on fibre- metal 110!
Use the singles auto dark shade 11.
I have two. They don't wiggle on your head and they are dang tough. I wore just about everything. Like the fibre- metals. The only hood more comfortable is a pancake in my opinion. They are not real versatile though.
   / Welding helmet advice for a farmer #6
I would go with a auto darkening helmet. I have a Miller. The bigger the lens and the more sensors they have the better it is.
   / Welding helmet advice for a farmer #8
Get an auto, especially if you're stick welding. MAkes it easier to strike an arc right where you want it.
   / Welding helmet advice for a farmer #9
I stick weld wearing a $50 autodarkening helment from Northern Tool. Works fine. Never been flashed.
   / Welding helmet advice for a farmer #10
I also have the $50 auto-darkening helmet from NorthernTool (Wel-built I think). Just used it Saturday. Auto-darkening is the best thing since slice bread!
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2018 Ford F-550 Truck Altec AT40G 40ft Insulated Bucket Truck (A50323)
2018 Ford F-550...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
Kubota ZG327 (A50120)
2022 Kubota B2601 (A50120)
2022 Kubota B2601...
