3020 jd diesel in oil
   / 3020 jd diesel in oil #1
lazybum
JD 3020
I checked my oil and it was way over full and very thin
drained it and got 4.5 gallons out of it
did I get diesel in my oil?
how do i fix this problem?
thanks
   / 3020 jd diesel in oil #2
thanks
This usually means only two things. A bad fuel injector, or your mechanical fuel pump has let a seal go and oil is making its way into your crankcase.
   / 3020 jd diesel in oil #3
Usually a bad injector will show up as a engine miss or black smoke. I'll vote for faulty lift pump(1st and easiest thing to check) or cup seals on inj pump drive shaft.
   / 3020 jd diesel in oil #4
ya the guys are wright i would say injector pump this happened to my fathers 580 case backhoe .new seal $600 later away he went . and if there is fuel in the oil DONT run it ....it will take out the crank
I will do the lift pump first, there has been some exterior seepage there
thanks!!
   / 3020 jd diesel in oil #6
I would also check for blow by
Jason
   / 3020 jd diesel in oil #7
I had the same problem with a 820 it was cup seals in the injection pump, also learned you need a special tool to install the cup seals.
   / 3020 jd diesel in oil #8
One doesn't "have to have" special tool but it sure makes correct installation easier.
   / 3020 jd diesel in oil #9
Can you share some advice/ technique that will work with out the tool, please share it. I would appreciate it..
Thank you Tx. Jim
   / 3020 jd diesel in oil #10
Turn pump upside down and after replacing u-cup seals(parts key #18) on drive shaft,lubricate the seals then carefully slide the shaft into pump(being careful to line up dots) so as to not wrinkle the first cup back. The JD tractors that are very difficult to install inj pump without a tool are the models that the shaft stays in the engine
2017 Ford F550 Service Truck (A53422)
2017 Ford F550...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
