'73 MF135 Perkins diesel AD3.152 help
   / '73 MF135 Perkins diesel AD3.152 help
When I lower the 3ph using the left aux. control lever, if I try to go down fast or full stroke on the lever, I can feel something "bouncing" back. Almost like the cylinder was hitting a gear or something.
   / '73 MF135 Perkins diesel AD3.152 help #42
I don't know about the valve, but if you're referring to the hydraulic lift cylinder "hitting a gear or something", there really isn't anything for it to hit. Here are a couple of pictures I took as I was rebuilding mine. The first picture is of the lift cover without the control linkages or the lift cylinder installed, and the second picture is of the complete assembly.
Copied this from Hutch off of another thread. Explains the operation very well:
"On tractors NOT equipped with the remote hydraulic control valve (under seat) the "inside" lever, the one you describe as having the square knob, is the POSITION CONTROL lever. When there IS a remote hydraulic lever, it's left in the constant pumping position and the remote service valve is used to control the 3-point hitch. However, WITHOUT the remotes (levers under seat), that "square knob" is used to control the 3-point hitch for any functions where position control is desired. The DRAFT CONTROL lever (round knob) is left in the fully raised position while using position control. When DRAFT CONTROL is the desired function, such as when plowing, the position control lever is left in the "transport position" (mostly raised....and up against a stop tab) and the DRAFT CONTROL lever is used to raise/lower the 3-point hitch ONLY when using DRAFT CONTROL should you be using that round lever.
On SOME earlier models of the 100 series, BOTH levers had a round knob. The POSITION CONTROL lever is on the inside, nearest the seat. DRAFT CONTROL lever is closest to the fender.
There is a "draft response" control near the right heel, just above the running board. That controls the flow through the lift system. Speed of raising and lowering the hitch can be adjusted there. It's best left in the "fast" position if a remote hydraulic service valve option is installed.
The original poster describes a typical OEM Massey Ferguson remote hydraulic service valve. (under seat, between legs) When that valve is installed, the POSITION CONTROL lever is left in constant pumping position all the time. The service valve should have 2 levers. The lever on the right controls the position of the 3-point lift. The lever on the left controls flow to the remote quick couplers. DRAFT CONTROL function is still controlled by that "round knob" lever nearest the fender. Position of the 3-point hitch when NOT using the draft control is controlled only with the right hand lever on the remote service valve. You have "up", "neutral", and "down". There is no real "position control" as such. The hitch can, and usually does drift somewhat with the hitch controlled by that service valve.
So, long story short, WITHOUT a service valve, you should be using the "square knob" lever (only) for MOST of your 3-point hitch control functions, with the "round knob" lever left in the raised position. When using soil engaging implements (ie a plow) and draft control is needed, use (only) the "round knob" lever to control the hitch and leave the position control lever in the "transport position" (raised). WITH a remote service valve, ALWAYS leave the "square knob" lever in "constant pumping" position (fully raised) and control the 3-point lift with the right hand lever on the service valve under the seat. That function WILL NOT provide "position control". Draft control function will be the same as is without the service valve, using the "round knob".
Using the DRAFT CONTROL function/lever to raise heavy implements on the hitch generally results in less than stellar performance. It tends to "bob" up and down, not lift all the way through the range of motion, and not stay fully raised once lifted. Also, the weight of the implement sends a "heavy draft load" message to the draft control system, causing the lift to either try to raise, or if heavy enough, just completely dropping the load.
If you DON'T need the remote hydraulics, that valve under the seat can be easily eliminated. (using a blank plate to replace the valve) That will restore full control function to the 3-point control quadrant. (levers next to fender). The position control function of the quadrant is far above "average" for accurate position control. It will hold a mower in an exact position for hours of use with ZERO drifting." - Farmwithjunk
   / '73 MF135 Perkins diesel AD3.152 help #44
Thanks Lugnut and Farmswithjunk I made a copy of this for my book. How is FWJ doing?
   / '73 MF135 Perkins diesel AD3.152 help #47
After reading the post from Hutch, it doesn't seem like my system operates as he describes it. When I purchased the tractor the owner told me I needed to have the left hand lever pulled back toward the seat and use the position lever next to the fender as if the auxiliary valve did not exist. Based on what i read from Hutch I believe he is saying that I should be able to raise and lower the three point from the auxiliary valve and not have to use the position normal position lever. As I stated before it never made sense to me and I will need to check into it further when I get back to the acreage. It may have something to do with the valve not being set for either a single acting or double acting system.
   / '73 MF135 Perkins diesel AD3.152 help #48
So what is the purpose in the left control valve? So I can lock the left control valve in the rear detent position and use my normal controls?
If your not going to use the controls why not just remove it and put a thirty dollar salvage price cap on it and use your lift and draft controls as textbook described. You could alway put it back if you ever had the need to control an attachment. Just a thought. -robert
Message posted with TractorByNet v1.6.2 for iPad
   / '73 MF135 Perkins diesel AD3.152 help #49
If it operates the three point as Hutch has explained, what reason is there to change anything. You may sometime in the future decide you may need it for a log splitter or some other attachment. The standard tractor hydraulics are only for use with a single acting cylinder. Its not leaking or in the way. I think I can quote someone from TBN "if it isn't broke, why fix it.
Well the alternator was bad, found a replacement at O'Reillys that was for an 81 Chevrolet truck. Only $48!
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2008 Ford F-750 Fuel Service Truck, VIN # 3FRXW75S88V075566 (A57453)
2008 Ford F-750...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
*Selling at Royal Auction Zephyrhills, FL Location* (A59231)
*Selling at Royal...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
