where to shop for a welder
   / where to shop for a welder #11
If it says Lincoln Exaclibur. It's top of the line. If it says Lincoln fleetweld, it's just under that. There are plenty of good everyday rods out there. One of the best welding rods I have used is also the cheapest. It. U.S. Forge by Messer. Anything I have used has been smooth as silk in that brand...Several companies around here sell them cheap, but it's not at all a bad rod. Hobart used to be my go to rod before Airgas quit selling them as their mainline and went to the cheapo Radnor brand they in house sell which hasn't proven to me a very good rod, though someone might like it.
   / where to shop for a welder #13
I've had pretty good luck with 5/32-inch Radnor 6010. The local AirGas is having some 5/32-inch ESAB 10P 6010 shipped in for me. I really like the 1/8-inch 10P.
   / where to shop for a welder #14
SMAW to start
thanks
I think you'd really like Hobart's 335A 6011, and ESAB Atom Arc 7018. I ordered some ESAB Acclaim 7018, when it comes in I'll give a review of what I think of it.
   / where to shop for a welder #15
I have been using the US forge, because it is convenient to buy locally, cheap, and seems to give good result. Not saying it is best or anything like that, just a good rod.
James K0UA
   / where to shop for a welder #16
>looks like a direct factory ship deal. Anyplace else I should check out? Do the welding supply shops sell welders competitively<
I'm in the very same dilemma. I'm within a couple of days of buying a small MIG welder. At this point, I'm pretty settled on the Millermatic 211 MVP. The thing that has me stymied is the difference in internet prices and the brick & mortar prices. Brick & Mortar is asking about 20% more for the same machine and supplies.
I love to support local businesses. But 20% upcharge on an already expensive welder is outrageous. They'll have my normal continuing consummable supply business as well as the occasional accessory business. I just don't feel they're right in a 20% upcharge (plus tax!) simply because they have rented some rag-tag building and hire some illerate to write up my order.
So, at this point, I'm totally undecided. Done with rant :)
   / where to shop for a welder #17
When I bought my Lincoln V350-Pro, I got my best price on the Internet. Called my local welding supply to get a price from them. To big of a ticket item for the counter guys. They turned it over to the outside sales rep. He called a couple days later. $500.00 higher! I asked him to trim some fat because I wanted to buy from them, he couldn't do it. When the machine arrived, it didn't work quite right called the local welding supply to see if they had any ideas. Store managers sent the outside sales rep to my house, because he use to be a repair tech for ESAB. He worked with the welder for 45-minutes and couldn't figure out the problem.
You have to remember, it's only a job to them. They don't take it personally!;)
   / where to shop for a welder #18
James K0UA
They are surprisingly good aren't they?
The Fleetweld 180's from Lincoln are king though for "farm" 6011 use around here a no shop is without them it seems.
   / where to shop for a welder #19
Hobart's 335A 6011, and ESAB Atom Arc 7018. ++1 just finished up a 50 lb box of them hobart 6011's. and have at least 100 lbs of the esab atom arc 7018s in the shop. welding store recommended inweld 6011 as a cheaper alternative .just got em so anyone ever used inweld?
   / where to shop for a welder #20
Yes, I've used several Inweld products. Never had an issue. But haven't had the 6011's. I have some aluminum rods here now from them.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51691)
2007 Ford F-550...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53473)
Mitsubishi FG35...
