Loader Hydraulic disconnect problem
   / Hydraulic disconnect problem #1
badels
Member
Casper, WY
JD 3520 w/Cab
Hello guys, I feel I have a silly problem. I cannot figure out how to disconnect the hydraulics to the loader on my 2008 1533 for removal. The disconnect will not release the fitting. I always assumed the fitting was like an airhose fitting but it is not acting that way. Is there a trick I am missing??? Yes, the pressure is bled off.
Thanks
Brad
   / Hydraulic disconnect problem #2
Reconnect the other lines, shut the engine off and move the loader control in all directions several times. There is probably pressure in the line(s) that wont come off.
Aaron Z
   / Hydraulic disconnect problem #3
Few people have trouble disconnecting.
Pressure build up due to heat prevents connections sometimes, and there are many different ways to bleed the pressure and connect.
Some QD's have a two way sleeve push or pull. Some also have a unlock and push pull sleeve, or unlock and pull.
   / Hydraulic disconnect problem #4
If there is pressure in the lines of our B7500, one of the loader quick connects will not release, that's why I suggested that first.
Aaron Z
I got it figured out. They are just a jerk out connection. Thanks
Brad
   / Hydraulic disconnect problem #6
I had the same problem first time I unhooked too. A tip... plant those loader kickstands on a firm surface ! If it ever sinks into the ground on ya it's tough to line back up on reinstall. Trust me.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
Kubota ZG327 (A50120)
2013 KENWORTH T800 FLATTOP SLEEPER (A55745)
2013 KENWORTH T800...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2002 CPS TRAILER COMPANY BOTTOM DUMP TRAILER (A55745)
2002 CPS TRAILER...
