Cab housekeeping.
   / Cab housekeeping. #11
No water for me! shop vac, and windex with paper towels. Outside I use pressure washer when hooked up, other wise garden hose, soapy water and long handle brush, windex the windows.
   / Cab housekeeping. #12
No water in the cab . Pull the floormat and vac or blow it out . You will be surprised at all the dirt under that mat . I like Windex and old newspaper for the windows . Try it , no streaks .
Dido on the Windex and newspaper. :thumbsup:
   / Cab housekeeping. #13
My tractor has a removable tray type mat I remove and shake out luckily
   / Cab housekeeping. #15
The best window cleaner I've found is rain x windshield washer fluid. Dries fast with no streaks
   / Cab housekeeping. #16
Windex for the glass, and a long compressed air wand for the dust.
   / Cab housekeeping. #17
No water in the cab here either ... Windex, papertowls and A GOOD WIFE !!! She is streak free on window detail.
   / Cab housekeeping. #18
Real believer in RainX, here as well. I add the RainX stuff to the washer reservoir, too.
AKfish
   / Cab housekeeping. #19
   / Cab housekeeping. #20
HaHahaaaa! Yep! That mud'll dry hard sometimes! I have to get out the hose or power washer. don-ohio :)^)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2010 MULTIQUIP 25KW GENERATOR (A58216)
2010 MULTIQUIP...
Hercules Safe (A57149)
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
