3415 new holland tractor.. rod broke and busted block..i need motor parts
   / 3415 new holland tractor.. rod broke and busted block..i need motor parts #1
tractorguy2000
botden indiana
3415 new holland
OK.. I have a 1999 to 2001 3415 new Holland 48hp tractor.. last night it through a rod through the block.. where can I find a good used block or used engine? Not sure what to do at the point.. I can't seem to find parts for this tractor.. is it a total loss? Should I just sale the tractor for parts or part it out.. I just can't beleave there is no parts for this tractor.. please help..
   / 3415 new holland tractor.. rod broke and busted block..i need motor parts #2
   / 3415 new holland tractor.. rod broke and busted block..i need motor parts #3
I would ask this question in the NH section. RickB a regualr poster there will be able to help as will others.
I thought I was in the new Holland part.. this is my first time post in like this.. how do I go about that..
I called .. and all had busted blocks.. thanks for the info DJ54..
Jerry.. do u know the link to the nh section?
   / 3415 new holland tractor.. rod broke and busted block..i need motor parts #7
G'day at the bottom right of the screen just above the box you write your reply in is a quick navigation bar, click on it and scroll down to the NH section and click on the one you want
Jon
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
