how stong is my 431
   / how stong is my 431 #1
araz33
Just purchased a new place, bought with a MF431. Sold my Ford 4600 thinking I would never need it again. Now I need to turn the sandy loam over to sprig with grass. It looks and feels like it is compacted. Flat as can be since once used as a grass farm.
Two questions:
I have read it is rated at 50 HP- will it pull a 7 ft tandem disk? Is it too much for this tractor?
Will it be easier and more efficient to plow first?
I figure 6 HP per foot and that would be close.
Thanks for the help
   / how stong is my 431 #2
Looking at tractor data .com it seems that it's about equivalent to your Ford 4600 powerwise so it should handle a 7ft disk especially if you have loaded rear tires.
I'm no farmer but if the soil is compacted, deep plowing or ripping might be required first in order to breakup a plow pan.
   / how stong is my 431 #3
Two questions:
Thanks for the help
The MF 431 uses the Perkins 1103C-33 engine and is rated at 44 PTO HP.
It will pull a 7' tandem three point mounted disc in just about any conditions but will likely need ballast in plowed ground. This should not be an issue as you will likely need ballast to plow in any event unless you have very good ground and/or use a small plow.
The tires that came on my 533 (2007 equivalent of the 431) are long wearing and smooth riding on hard surfaces but do not bite well. Too much rubber in the center of the tread.
SDT
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2007 Sterling L7500 Terex Commander C6060 60ft Insulated Derrick Digger Truck (A55973)
2007 Sterling...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
