BUCKET RATCHET RAKE
   / BUCKET RATCHET RAKE #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
   / BUCKET RATCHET RAKE #2
Weird. How the heck do you use the teeth on the top? For pulling vines out of trees? Seems like a lot of fabrication effort for a bucket that can't hold very much.
   / BUCKET RATCHET RAKE #3
What he said.
It should do the same thing a ratchet rake will do, and use it as a bucket at any time.
How about root rake.
It could probably be built with more throat length, or any size.
I see lots of potential there.
Think of this. Put another tooth bar on top of the bottom teeth and a hyd motor to slide it back and forth, like a sickle mower. HUM, should I make something like this?
   / BUCKET RATCHET RAKE #5
If your bucket linkage allows, you can put the top teeth into the dirt. This may be why the "floor" of the bucket is short.
http://www.mytractortools.com/images/angled end plates.JPG
http://www.mytractortools.com/images/Tach-n-Go hook up.jpg
The "teeth bars" are "reversible." This may mean they can be reversed to a smooth edge, or reversed to top or bottom edge of the bucket. The top could be a handy place to store your spare teeth, and increase the bucket capacity a bit.
New Box Rake for Tach-n-Go
Bruce
   / BUCKET RATCHET RAKE #6
That's what I was thinking. The top of the bucket doesn't put the loader in the best position for any type of ground engagement. Some folks will find an excuse to build anything I guess. Maybe the next product offering will be a bolt-on tooth bar for the top of buckets?
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
2019 Ford E-450 Super Duty Passenger Bus (A48081)
2019 Ford E-450...
2015 Ford Fusion S Sedan (A48082)
2015 Ford Fusion S...
2018 Chevrolet Bolt EV LT Hatchback (A48082)
2018 Chevrolet...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
Small BBQ PIT (A50860)
