Is there a limit to the number of mice you can trap in a barn?
   / Is there a limit to the number of mice you can trap in a barn? #41
The RV antifreeze is not toxic like Ethylene Glycol is.
I'd think twice before putting mice drowned in this stuff on posts for hawks to eat.
   / Is there a limit to the number of mice you can trap in a barn? #42
Why? you have eaten plenty of it in foods, drinks, and medications. (propylene glycol) and so Have I. It may be killing us for all I know, but it sure is approved by our government:)
   / Is there a limit to the number of mice you can trap in a barn? #43
I find that snakes are most helpful with the mouse population (non poisonous of course). I had one move into my garage and suddenly the mice were gone. I can also vouch that the red tails don't seem to eat dead rodents. I've tried to feed mine plenty of times and he ignores anything that's not living. He actually appears to focus on birds and squirrels more than mice for whatever reason, though we've got plenty around. The bucket trap works good with just water, or water and a bit of RV antifreeze if its below freezing, I also use a rat zapper trap, which is decent (but don't get shocked by it)
   / Is there a limit to the number of mice you can trap in a barn? #44
yep.. toothpaste.. cough syrup.. lots of stuff .. many products PG instead of glycerine due to cost...
   / Is there a limit to the number of mice you can trap in a barn? #45
According to Whole Dog Journal:
~90,000 pets are poisoned each year by ingesting antifreeze.
Antifreeze will soon have a bitter flavoring agent added to mask the sweet taste that attracts pets.
Older antifreezes are 95% ethylene glycol, an easily absorbed alcohol.
One teaspoon can kill an average cat.
The minimum lethal dose in dogs is 2 ml (about 1/2 teaspoon) per pound of body weight.
Some newer antifreezes use 50% or more propylene glycol in place of ethylene glycol, but can still cause alcohol poisoning.
Doses greater than one teaspoon per pound of body weight are potentially toxic to dogs.
   / Is there a limit to the number of mice you can trap in a barn? #46
apparently whole dog journal needs to update it's records.. I think they are still living in the 50's and 60's.
true alcohol based AF is QUITE old.
as for propylene glycol
It is in the 'generally recognized as safe' category by the FDA.
It is also used in many oral and injectable preparations for materials not miscible in water.. like some benzodiazapines.
it's one of the main ingrediants in my mouth wash... a quick check showed it to be in about 20 products in my bathroom tht either go on my skin or are slightly ingestable.. or meant to be ingested.
soundguy
   / Is there a limit to the number of mice you can trap in a barn? #47
Scientists found out what causes pain in the brain for rats and mice.
They think it may have something to do with the metal bar that hits
them in the back of the head when they go for the cheese.
:laughing:
   / Is there a limit to the number of mice you can trap in a barn? #48
soundguy
It is apparently the alcohol poisoning that is lethal to dogs and cats. The risk factor is how does that dose of alcohol affect a dog, and the sweet taste makes it attractive to drink.
Human alcoholics do drink mouthwash.
I'm not up on chemicals like you, but here are some quick google hits:
According to this in 1999, Prestone contained 80-96 percent ethylene glycol. http://www.nukaresearch.com/projects/SeldoviaHarbor/documents/MSDSAntifreezeEG.pdf
This one, PAR coolant, was 94% ethylene glycol in May 2007. http://www.kmcoinc.com/antifreeze MSDS.pdf
Castrol: 90-95 percent ethylene glycol.http://datasheets.bp.com/ussds/amersdsf.nsf/0/04226F062D82F07186257307004F931C/$file/014244US-Lubes%20Americas-BP%20(Wayne,%20NJ%20US).pdf
   / Is there a limit to the number of mice you can trap in a barn? #49
But the antifreeze being referred to here (for use in a mouse trap) is RV antifreeze, it is intended for use in RV waterlines to keep them from freezing and as such, non-toxic (or not very toxic at least) to living beings. Here is the MSDS for some RV antifreeze made by Prestone: MSDS PRESTONE RV ANTIFREEZE showing Propylene Glycol as the active ingredient.
Aaron Z
   / Is there a limit to the number of mice you can trap in a barn? #50
Why do you KEEP referencing Ethylene glycol ( toxic ) antifreeze, when we are discussing propylene glycol antifreeze.
citing studies that are using data on toxic antifreeze in an argument about different materials is befuddleing????
rv antifreeze is PG.. NOT EG. your dog people apparently are 4 decades behind the times.. or are otherwise intentional obfuscating the issue for some reason???
2007 International 4200 S/A Chipper Truck (A56858)
2007 International...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
2019 GALYEAN...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
