Farmall A/ What year is my tractor?
   / Farmall A/ What year is my tractor? #1
Jerry Stevens
Oklahoma
1945 Farmall A & 1965 Ford 5000
I found my S/N on the block:
FFA 1 335704
Not sure about the 1 but I think this is right. Can anyone tell me what information I can get from this S/N? Thanks in advance!
Jerry
   / Farmall A/ What year is my tractor? #2
52 and that would make it a Super A. There should be a matching one by the right side seat support
   / Farmall A/ What year is my tractor? #3
Serial plate found on right seat support.
A
939: 501
1940: 6744
1941: 41500
1942: 80739
1944: 96390
1945: 113218
1946: 146700
1947: 182964 (Chicago)
End: 198298 (Chicago)
1947: 200001 (Louisville)
End: 220829 (Louisville)
Super A
1947: 250001
1948: 250082
1949: 268196
1950: 281269
1951: 300126
1952: 324470
1953: 336880
1954: 353348
Thanks, somone before me traded out the seat so the S/N is gone. So it's a super A huh? Do you know what is different from a standard A? Mine has no hydraulics on it.
A
939: 501
1940: 6744
1941: 41500
1942: 80739
1944: 96390
1945: 113218
1946: 146700
Super A
1947: 250001
1948: 250082
1949: 268196
1950: 281269
1951: 300126
1952: 324470
1953: 336880
1954: 353348
   / Farmall A/ What year is my tractor? #5
Does it have a water pump?The block is usually a slightly different shape around where the hydraulic pump would normally be.Is the oil filler on the side of the block or in the top of the rocker cover?Does it have the round tube front axle of the square axle?Serial number should be FAA335704
I don't believe that it does. Two belts one going tothe fan and the other off the fan to the Gen. Oil filler is in the vavle cover. It has the round tube front axle. S/N is:
FAA 335704
Jerry
   / Farmall A/ What year is my tractor? #7
If it is a SA then it should have a hyd. system and rock shaft! (thats what I was told) thanks; sonny580
   / Farmall A/ What year is my tractor? #8
   / Farmall A/ What year is my tractor? #9
C
1948: 501
1949: 22624
1950: 47010
1951: 71880
Super C
1951: 100001
1952: 131157
1953: 159130
1954: 187788
   / Farmall A/ What year is my tractor? #10
thanks!
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
John Deere (A50322)
John Deere (A50322)
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
