Starter burned up in the big diesel rig? No problem!
   / Starter burned up in the big diesel rig? No problem! #2
I dont think the C-16 in my truck would start that way !!
That engine probably has a zillion miles on it and is llikely low on compression to start with. I don't think that would work with a new engine.
   / Starter burned up in the big diesel rig? No problem! #4
I seen that done on a episode of MaCGyver
Chris
   / Starter burned up in the big diesel rig? No problem! #5
Done it with an old VW and an old 4cyl Jeep when they had dead batteries.
Bruce
   / Starter burned up in the big diesel rig? No problem! #6
Is the clutch and brake working right? Who's job is it to crawl under the truck and get the jack out?
The guys mowing Mom's hay last year apparently blew a starter motor in one of their tractors so they were push, or pull starting the tractor, then managed to do something and tore out the transmission. I still have troubles imagining what they did, but perhaps it is best to just fix the starter motor.
   / Starter burned up in the big diesel rig? No problem! #7
Yup it wont, because it needs a turn before the injection management has its timing right, it must first get a timing sensor readout... Also some engines delay injection for a few turns so the hydraulic valve lifters can fill up before ignition.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Year: 2014 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2014 Make...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
SAMSUNG REFRIGERATOR/FREEZER (A58376)
SAMSUNG...
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
