Test running a rebuild
   / Test running a rebuild #1
curt3969
Massey 35
I would like to test my rebuild out before I install it in the tractor. Just to be sure everything checks out and fix any trouble now. I see on you tube that this can be done. Has anyone here tried to do this and also what is the right way to do it? It is a 3.152 Perkins out of my Massey 35.
   / Test running a rebuild #2
We did this on car engines by making a complete test stand. Its a lot of work to do it right, not for a one-off.
   / Test running a rebuild #3
I considered buying or building a test stand to break in my Massey 135 tractor's Continental Z-145 gasoline engine, but decided to wait until later. Here's what I found as a source for inspiration... they aren't cheap.
   / Test running a rebuild #4
That's pretty neat ours was much cruder than that but it did all engines. We charged 150.00 back in the 70s to test run your engine.
Well, thats a bit more than I can get. I'll figure out something.
   / Test running a rebuild #6
It's totally redneck, but you could set the engine in an old tire, hook up the radiator or a garden hose, then connect the wiring to a battery and go. It ain't pretty, but it does work. Something like this...
   / Test running a rebuild #7
Alternatively, you could modify an old pallet, hook up the radiator or a garden hose, then connect the wiring to a battery and go. Something like this...
Well, since I am an official redneck, that's perfect. I just need to figure out the fuel thing.
   / Test running a rebuild #9
An old lawnmower gas tank can be used to supply fuel, or one can get creative and use an inverted 2 liter soda bottle with a pipe nipple through the lid. Connect a piece of rubber hose, and you're off to the races.
   / Test running a rebuild #10
Why do you want to test on a stand?
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
UNUSED Hook & Eye Turnbuckle Set (A50860)
UNUSED Hook & Eye...
Tubing A500 Grade C 6in. SQ x 1/4in. x 28ft. (A50860)
Tubing A500 Grade...
2012 Ford Focus Hatchback (A48082)
2012 Ford Focus...
2008 GMC Yukon SLE 4x4 SUV (A48082)
2008 GMC Yukon SLE...
