New Holland 930B Finish Mower
   / New Holland 930B Finish Mower #1
Anguss
Lathrop, Mo.
Ford 3000 Tc45d
Do you have to remove Gear box to put on new belt on this mower?
   / New Holland 930B Finish Mower #2
I was wondering this myself. Bought mine used and thought I'd swap the worn belt before it breaks so I can compare the size to the Gates 120''. I've read a thread here about troubles with correct size belts. Did anyone reply with the answer to the gearbox question?
   / New Holland 930B Finish Mower #3
Mine is a Ford 930B finish mower, and I don't remove the gear box to replace the belt. It has been a while since I replaced the belt and don't recall exactly how. Mower and manual are in Michigan. I am where it is warm. If you do not receive any other replies, PM me in May and I will send you instructions from the manual.
   / New Holland 930B Finish Mower #4
Typically, there is space between the mower deck and the pulley beneath the gearbox, which would allow you to slide the belt under the pulley to install. But, if removing the gearbox is handy, it is always a good time to drain and replace the gear oil.
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
