Fixing Up Drive Right
   / Fixing Up Drive Right #12
I have got a 1200 foot drive that needs some gravel put on top. I am not sure what happened to the original stones but they seem to disappear over time. This property I bought a year or so ago and I want to fix it up right the first time. I contacted a quarry that will drop it along the drive. They priced out crushed limestone 310 at 12.50 per ton and #57 limestone at 13.50 a ton. I am thinking the #57 is the better product as it looks like it is bigger and less dust. Any downside to #57 besides the price. Anything else I need to consider? I am in central Ohio. Thanks
I
put slag on my driveway,it comes out of the steel mills.Best stuff IMHO holds up real well.coobie
   / Fixing Up Drive Right #13
Around here we call it crusher run...
You can also get screenings that we use on ball fields out at the Optimist Park...
I have heard that the best way to build a good road is to use regular washed stone and then put crush run over top...
I have always just done it in reverse...
I need some stone hauled myself...
   / Fixing Up Drive Right #14
There is no need to wash the stone in the base. Screening out the dust is good enough.
One of the best roads I ever worked on started with a foot of sand covered with eight inches of 5" minus crushed ledge then four inches of fine 3/4" crushed stone and three inches of pavement. The 5" ledge has to be placed with a D-8 sized dozer and the operator needs to keep the blade near full to be able to grade it.
That road is a commercial strip with 30,000 cars a day on it and leads to the concrete and asphalt plants as well as a landfill so gets a lot of heavy trucks. They have over laid the asphalt just twice in thirty five years.
The five inch stones interlock like a puzzle and spread the loads from tires over a larger area of the sand below. To make it they run the output of a big cone crusher over an inch screen and separate all the fines out and send them off to a smaller crusher to make the 3/4 mix .
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A55787)
2007 Godwin Pumps...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
(INOP) 2020 KUBOTA X1100C RTV (A51406)
(INOP) 2020 KUBOTA...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
