Plasma cutter with pilot ir not?
   / Plasma cutter with pilot ir not? #1
yarg
UP of michigan
L48 Kubota
Hi,
Lots of questions but this about a pilot being worth it or what advantages?
Everlasting p or no p
Thanks,
Gray
   / Plasma cutter with pilot ir not? #3
I would not consider a unit without a pilot arc.
IF you are asking about our Everlast products (I gather from the word Everlasting), I would recommend the PowerPlasma 50 many times over the SuperCut 50 or the SC 50P. Better built, better technology.
It has pilot arc and it uses a torch that has consumables commonly available. No high frequency either...which is a good thing. The Supercuts use HF and it doesn't play nice with electronics.
   / Plasma cutter with pilot ir not? #4
Pilot arc is a MUST if you are ever going to cut any sort of grating or expanded steel. My Hobart has it, and I would not consider one without it after having it!
I hope to do some light fabricating so I woukd guess a 50 amp should do?
Do these units need a pilot hole drilled to get a good point start?
3/8 " will be common thickness. I am also looking at a Makita cold cut chop saw for my 1/4 x2.5" angle iron and up to 7 x 3/8 flat also some 3" sch 80 pipe.
Thank you all for sharing.
Gray
   / Plasma cutter with pilot ir not? #6
To OP...
A budget may help the members steer you in a certain direction/brand
500-800 for plasma
450 for cold cut saw
600-900 for mig,stick spool gun unit?
   / Plasma cutter with pilot ir not? #8
I find the "consuables" get "consumed" at an expensive rate & grab the O/A most of the time, it may just be me but if I had a do over, I'd a spent that $1200/1400 bucks on something else. (Hypertherm 900 ? I think about 8/10 yes. ago) Now to be fair I do not have a fancy air dryer in my air sys.
Ok, so take the cold cut saw out and what should I expect to pay for a good 1/2" clean cut plasma and a spool gun with a 180 to 200 amp MTS unit?
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
1999 Mack MaxiCruise CH613 (A50120)
1999 Mack...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
