1945 Farmall A Hydraulics?
   / 1945 Farmall A Hydraulics? #1
Jerry Stevens
Oklahoma
1945 Farmall A & 1965 Ford 5000
Is there anyway to install hydraulics on subject tractor other than the old exhaust lift?
   / 1945 Farmall A Hydraulics? #2
Mount a power steering pump on it, run it off the fan belt.
   / 1945 Farmall A Hydraulics? #3
My 2 cents: Farmall 55a has a good point, but in my experience your limited in flow and pressure ( umph or aka balls) if you need it. If your looking to add a loader to your A, I'm afraid you won't have enough "umph". If you look on some of the discount web sites like Northern Hydraulics, you can purchase a self contained hydraulic system for under $500.00 new. If you are thrifty, like me, I used an old snow plow hydraulic unit I had kicking around (electric over hydraulic) A bit more umph than the power steering unit I used on another tractor. Issue there would be if you still have the 6 volt positive ground electrical system on your Farmall A. In that case, mechanical (belt or PTO drive) would be better.
Hope that helps...
Rick
   / 1945 Farmall A Hydraulics? #4
Good Afternoon Jerry,
The power steering pump is probablly your best bet. They also make hyd pumps that fit on your PTO but of course every time you disengage your clutch your pump stops spining...
I have both A and Super A, there are plenty of Super A tractors out there looking for a home and a face lift ! :")
   / 1945 Farmall A Hydraulics? #5
transplant from another small letter series with hyds. :)
   / 1945 Farmall A Hydraulics? #6
Check the parts yards for a used factory SA complete hyd. system!---they wont be cheep, but it depends on how bad you want/need one!---one of my cubs has a HAND lift, so there is another option, there again depending on intended use of tractor! thanks; sonny580
Thanks Sonny580, I'll do that!
   / 1945 Farmall A Hydraulics? #8
keep us posted!
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
Payment Instructions (A47384)
Payment...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
