PHD for a SCUT?
   / PHD for a SCUT? #1
PsRumors
Gold Member
Cartersville (NW) Georgia
Kubota L45
Is there a PHD that has the lift arms appropriately sized for a SCUT? On my TZ25DA I had to cut down a top link because a standard one was way to long. Figure I'll run into the same problem with a PHD.
Thanks
   / PHD for a SCUT? #3
Yes there is I have one on my massey, but the auger is only 2 ft long. I don't recall the name brand and it is snowing so I am not going to the barn to check now. Will check later if you don't get a lot of answers before then.
   / PHD for a SCUT? #4
Thanks
Here's a video from Everything Attachments specifically about PHD's for the smaller tractors. This is different than the videos on the page link I gave you earlier in this thread. Also, the particular model shown in this video is an older version that has been replaced by the one on the earlier ETA web page.
www.youtube.com/watch?v=x32t43EuPuU
   / PHD for a SCUT? #5
This is fantastic. My neighbor was just asking about a PHD for his 1026r, and it looks as if this might work for him. My only concern was the down pressure from those small tractors. Does anyone have any experience using a PHD on the SCUT's?
   / PHD for a SCUT? #7
I have a standard size phd (old Speeco cat 1) that I run with my older JD855.
Augers must be about 42" (normal size ?) and it all works fine.
Good luck
   / PHD for a SCUT? #8
I wouldn't trade my SCUT for a PHD. Education is overrated.:confused3:
   / PHD for a SCUT? #9
Most tractors do not have down pressure on the 3PH.
Spool 19mm Wire Rope (A47384)
Spool 19mm Wire...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
3 piece Bale Ring (A50515)
3 piece Bale Ring...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
Raven BSR (A47384)
Raven BSR (A47384)
