a bit more Horspower for my B7200HST
   / a bit more Horspower for my B7200HST #1
benbeno
canada
B7200HST
I like to have a bit more Horspower for my B7200HST.another engine maybe fit to the trany?a Turbo is maybe to hot for the engine? what is the best? or better never think about this
Benbeno
   / a bit more Horspower for my B7200HST #2
Benbeno
What type of PTO work are you doing requiring higher HP?
Turn up the fuel screw maybe?
How much more HP are you looking for? Gotta stay realistic about any gains you may get
   / a bit more Horspower for my B7200HST #3
A turbo would be an awesome addition if the engine can handle it.
You may have better luck, and ultimately cheaper, trading for a bigger tractor. Of course if it is possible to turn up the fuel screw and you eked out 1.5 pto hp that is a 10% increase.
   / a bit more Horspower for my B7200HST #4
When you turn up the fuel screw do you have reduced economy for normal tasks, or do you only get the increase when the task calls for it? ... To me, for diesel it would seem the latter case. -- Anybody know :confused2:
larry
   / a bit more Horspower for my B7200HST #5
In any engine the air and fuel need to be optimized so increasing the injector pressure will dump more fuel but with the same amount of air will pour black smoke - run rich etc - not to say what the extra/unburned fuel will do to the pistons and rings.
Not a good idea unless you add more air also (turbo) or larger pistons. Long and short - I wouldnt do anything.
Carl
tx a lot for all those infos.It is only a idea from me to have a bit extra power on the pto.I'm retired now and got this B7200HST with a heated cabin, loader,snowblower,tiller and a extra skidlifter with only 520 hours on for a very good price.
and for my 6 acre + land and a 1000feet driveway,I have some work to do.but for a bit extra power I dont like to burn the engine down.I have work a lot(tuning ect.) on gas engines but for a dieselengine I have no idea at all.better I leave it as he is right now it wil be the best to save money for nothing.
again tx a lot and I use my time to give a new paintjob to this B7200
Benbeno
   / a bit more Horspower for my B7200HST #7
Carl
Yeah ~~ But what I was thinking is that air on a diesel is always wide open ... even at idle. -- This is a requirement for compression ignition. -- Throw more fuel in it tries to idle faster and the governor cuts back. At part throttle the governor should increase the injection to hold rpm as load increases. This increase should continue til you hit the limit set into the injector pump. Thats why Im thinking the fuel screw just increases that limit. It would follow that the engine would run the same at low to normal max load, but higher ultimate load would be possible by wasting a little diesel/black smoke. :confused3:
larry
   / a bit more Horspower for my B7200HST #8
Benbeno
Sounds like the best idea.
   / a bit more Horspower for my B7200HST #9
Adding a turbo would be nice addition to increase the PTO hp. Do not add a turbo to increase the drawbar HP on a hydrostatic transmission.
I added a turbo to my Ford 1720 which was rated at 23 PTO hp. My reason for the turbo was marginal hp when using my snow blower; it frequently required me to use the clutch to avoid stalling the engine.
I live the New England on a main road where the state highway trucks push up a deep heavy snow bank that I need to clear. My tractor was perfect in all other respects just lacked enough power.
I thought about a turbo for quite a few years. The project started when I found one at a swap meet for $35.
The results were nothing less than outstanding! Now it has the power to muscle thru the deep packed snow without using the clutch (abuse) to avoid stalling.
A turbo can actually cool the exhaust temperatures by supplying excess air which allows additional fuel to be injected and combusted.
Fuel consumption should not increase during normal use, if you don’t use the power it won’t use the fuel.
Turbo’s do not require larger pistons or increased injector pressure. You merely adjust the injection pump to inject more fuel per event. That’s all not rocket science.
Diesels operate with excess air unlike gasoline engines that require a precise constant air fuel ratio of 14 to 1 at all engine speeds.
Diesels operate at air/fuel ratios of 100 to 1 at idle to approx. 16 to 1 at full power.
Diesels are quite robust and for that reason tolerate turbocharging very, very well.
I would turbo it!!
90cummins
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
