Removing a decal from rental company
   / Removing a decal from rental company #1
BeezFun
IL
Kubota B2710
Bought a used piece of equipment from a rental place, it has their company decals on it and I'd like to remove them. They're pretty thick, I haven't tried any solvents yet. Any ideas on ways to get these things off? I tried picking at it with a razor blade, pretty tough going to get each little piece off. I don't want to make a big mess out of the paint job.
   / Removing a decal from rental company #2
Try a hair dryer or heat gun to soften the adhesive.
   / Removing a decal from rental company #3
Try a heat gun, or a hair dryer if you don't have one. Heat it up then try to peel it off.
   / Removing a decal from rental company #4
Often a heat gun (or hair dryer in a pinch) works very well. Just add heat near the edge and get it started. Then keep moving the heat forward and heating it as you go and most will peal off pretty easily. If you have residue, WD40, Goo Be Gone, or similar products work well. Be careful with using carb cleaner or strong solvents as they can soften the paint and cause you problems.
   / Removing a decal from rental company #5
Sorry Buzzard - we must have been typing at the same time and you beat me to the punch.... What he said!
   / Removing a decal from rental company #6
A pressure washer will remove decals. Unintentionally, even.
But I second the suggestion of a heat gun.
   / Removing a decal from rental company #7
On my new tractor I used wife's blow dryer to get the many 'safety' stickers off. Worked well. Philip.
   / Removing a decal from rental company #8
Even the GoofOff stuff can be troublesome. I used a bit on my backhoe and the rag turned Kubota orange. It was certainly removing more than just the goo.
   / Removing a decal from rental company #9
Use a heat gun and soften it up. A hair dryer might work.
   / Removing a decal from rental company #10
Heat and a STIFF plastic putty knife such as Shop Warner 2" Plastic Putty Knife at Lowes.com has worked well for me removing decals from a 15 passenger hotel van...
I followed that up with carb cleaner, the same putty knife and a cloth to remove the sticky stuff that is left.
Aaron Z
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
