Slow lift at top on dump trailer
   / Slow lift at top on dump trailer
If you don't have a breather and the pump was designed with one that could be the problem, the pump could be creating vacuum in the reservoir and can't correctly pull fluid, the reservoir must have a way to get some air in for the fluid the pump has displaced.
You can add oil with the bed powered up (you should use the safety prop) , just have to be a little more careful not to overfill. Find the fill cap on your reservoir and verify that it is very low, add about 4~6oz of oil, test ,repeat if necessary, don't put in any more oil than it takes to get the cylinder smoothly to the top. Be aware that if you overfill when you drop the bed it will spit out any excess and make a mess.
Ray
Where does it spit out from? I will take a pic of mine and post it tomorrow
   / Slow lift at top on dump trailer #12
Thats just it , it usually comes out the breather, i've never seen one of those electric pumps on a dump trailer without a breather, but to be fair I'm most familiar with only one brand of those pumps so another brand may be different. That type of pump is also used on small dump trucks without PTO capabilities and again they always have a breather.
Ray
Electric Concrete Mixer (A51573)
Electric Concrete...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
KMC 5610 (A53084)
KMC 5610 (A53084)
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
