431 brake adjustment
   / 431 brake adjustment #1
araz33
Just acquired a 431 that was a bit neglected. Brakes were almost bottomed out the first time I used it. Tried to adjust but the star adjustment is frozen. Any ideas on how to break free without removing the tires and breaking it free. Should I just try and adjust with the turnbuckles and forget about it?
   / 431 brake adjustment #2
You will need to remove the brake drums to inspect the brakes. If the star wheels are frozen, which is uncommon, you will need to free tham. Removal of the wheels/tires and brake drums is not difficult.
Are you using a proper brake adjusting tool?
SDT
using a screwdriver- will any break adjustment tool work? is there one specific to 431?
   / 431 brake adjustment #4
Any automotive brake adjustment tool will work. Though probably possible, it will be more difficult with a screwdriver.
SDT
LOT IDENTIFIER 16 (A53084)
LOT IDENTIFIER 16...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
JOHN DEERE LOT IDENTIFIER 30 (A53084)
JOHN DEERE LOT...
